wheels and offsets |
JFG |
Oct 24 2017, 11:52 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I have a set of riviera alloys which i am thinking of fitting. I've seen some cars fitted with them in pictures only.
As i hadn't touched them since i bought them over a year ago i thought i'd give them a clean and good check over. When i measured the offset i calculate it as being et20! Standard fitment on a 914 is et40. So my question is how do they fit? If i put a spacer on i'm just going to push the tyres into the fenders. Have i bought the wrong size set? |
Oct 24 2017, 12:12 PM
They don’t typically work well with wider tires. More of a VW wheel than 914.
Oct 24 2017, 10:39 PM
You can likely run 165-width tires on them. Wider is pretty certain to rub, unless you've got flared fenders.
--DD |
JFG |
Oct 25 2017, 05:08 AM
I've found a set of fuch replicas. They are 5 1/2j et35. to enable a tyre choice what is the fitment gping to be like? Stovk fenders.
JOEPROPER |
Oct 25 2017, 05:52 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I have Riviera wheels on my "75 and I fitted 195/65R15s after rolling quarters on mine. I know a lot of people don't like the Rivieras, but I think they look good.
For some reason I can't add a photo... (IMG:style_emoticons/default/confused24.gif) |
JFG |
Oct 25 2017, 08:16 AM
I like the look of rivieras that's why i bought them. If i can find a matching 4th over here i'll stick with them.
Oct 25 2017, 08:53 AM
The Rivs were made in several different offsets. The ones intended for Bugs will not fit wider tires under 914 fenders. The ones intended for 914s will.
--DD |
larryM |
Oct 28 2017, 09:01 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
(IMG:style_emoticons/default/cheer.gif) use this calculator - http://www.rimsntires.com/specspro.jsp |
Lo-Fi Version | Time is now: 17th May 2024 - 06:14 PM |
