914/RS: Re-build and Re-design: Engine and Cooling |
Cracker |
Oct 24 2017, 08:45 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Well, I have never posted a "build" thread in the past - it will serve as my re-build as my car has been running for some time. Something that might be interesting for the H20 folks is a performance based cooling system - oil included.
The silver lining associated with the engine down is I have been intending to make the cooling updates for well over a year now. Its such a PITA I have delayed engagement. LS engines are notorious for running high oil temps on track - GM will tell you it is ok - I believe it is not. Likewise, mid-engine cars have a notoriously difficult time controlling temperatures simply because of the location of the engine and cooling systems. This is exacerbated with additional power. I walked the pits of the Walter Mitty Classic at Road Atlanta last year and took a bunch of pictures. All late-model mid-engined prototypes used Water-to-oil heat exchangers in lieu of oil-to-air. It adds a serious layer of complexity since the coolant now has to carry the burden of dispersing allot of extra energy. That is what I will be updating: all lines, the radiator, shroud addition, coolant distribution chambers, etc. One of the benefits of this new system is the ugly-as-sin rooftop oil cooler scoop will be eliminated (not to mention the drag that thing is causing ~ slowing me down)! Just remember, along with most other members here, I ain't no "Tygaboy"! (IMG:style_emoticons/default/bye1.gif) Tony |
Cracker |
Oct 24 2017, 08:54 PM
Pulled the engine today and dismantled to inspect for damage. Turns out I did in fact have a rod bearing failure - or so it appears. The cylinders all look and feel outstanding, as do the lifter bores - thank God. The heads were undamaged, pushrods were all straight, all very good signs and news.
One odd discovery that is pictured below was the fractured lower dry sump pump mount...chicken or egg scenario. Did this cause the failure or do the failure cause the mount to fracture. Dunno? How Ti rods should look... |
Lo-Fi Version | Time is now: 18th May 2024 - 01:59 PM |
