QUOTE(Cracker @ Oct 28 2017, 10:52 AM)
Interesting. Aviad and ARE who both contributed to the construction of my dry sump system gave that "rationale" as to why they wanted me to cool the scavenge circuit. My existing cooling system is inadequate (IMO) to add the W2O cooler as it sits currently...time will tell which method is more effective.
I'm surprised they didn't recommend the pressure side going something like tank>pressure pump>filter>oil cooler. This would give you the least aerated oil which would both help overall parasitic pumping loses since you wouldn't be forcing oil+air bubbles through a cooler and likely improve heat transfer. I'd be a bit worried about air collecting at a high point and effectively blocking some of the channels.
They definitely have more practical experience there, it's just interesting. Not what I would have expected for sure. I've only designed one dry sump system (it did work really well) and was not super impressed with the level of design data available from the pump manufacturer or heat exchanger manufacturers. Neither Aviad or Armstrong have much actual data on their sites. It looks like a lot of kits which culminated from BTDT. I'm not trying to say they are not very good at what they do, but its just very different than what you see when buying aerospace or industrial parts.
Slightly tangent, but the automotive aftermarket is a funny place. To date the only radiator/intercooler supplier I've talked to who can offer real engineering data is Bell-they actually deal with mass flows and energy dissipation requirements, not "HP". But maybe that's because of Gerhard Schruf?
QUOTE(Cracker @ Oct 28 2017, 02:52 PM)
The volume is not necessarily the same - the two circuits operate on completely different pumps and pick-up sources. I just do not understand where you are drawing that parallel from...we are installing what should prove to be a far more efficient radiator.
Sorry, confused there. Maybe I'm misunderstanding everything? I assume you have a number of pickup scavenge pumps>single outlet>tank and then a tank> pressure pump>engine. Then the coolant side uses a single pump/radiator with branch line through oil cooler?
QUOTE(worn @ Oct 28 2017, 11:45 AM)
You see the slower so it has time to cool story bandied about in the hot rod magazines too. It is not correct physically, but it sounds right. A lot of people who know a huge amount about engines aren't like me trying to figure things out going from college class to reality. As everyone knows, reality can turn around and bite you.
The slower thing just kills me-it's everywhere.
For sure, reality is tough. When you look at coupled systems, not a lot of stuff is very straightforward and sometimes it 'appears' to go against conventional physics. I think that's where some of these wives tales come into play. Then when you model the whole thing, the math shows deviation from physical expectations are caused by a bunch of factors acting against each other, etc.
Sorry to if I'm coming off as an armchair-internet-know-it-all. Just trying to share some of my engineering perspective and seeing what other people are doing is interesting. I've spent close to 10 years now designing/troubleshooting thermal management systems for power plants and high end aerospace/marine test systems and am almost finished with my PhD which focuses on aerospace combustion/heat transfer/fluids systems so I like to think I have some relevant experience.
