914/RS: Re-build and Re-design: Engine and Cooling |
Cracker |
Oct 24 2017, 08:45 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Well, I have never posted a "build" thread in the past - it will serve as my re-build as my car has been running for some time. Something that might be interesting for the H20 folks is a performance based cooling system - oil included.
The silver lining associated with the engine down is I have been intending to make the cooling updates for well over a year now. Its such a PITA I have delayed engagement. LS engines are notorious for running high oil temps on track - GM will tell you it is ok - I believe it is not. Likewise, mid-engine cars have a notoriously difficult time controlling temperatures simply because of the location of the engine and cooling systems. This is exacerbated with additional power. I walked the pits of the Walter Mitty Classic at Road Atlanta last year and took a bunch of pictures. All late-model mid-engined prototypes used Water-to-oil heat exchangers in lieu of oil-to-air. It adds a serious layer of complexity since the coolant now has to carry the burden of dispersing allot of extra energy. That is what I will be updating: all lines, the radiator, shroud addition, coolant distribution chambers, etc. One of the benefits of this new system is the ugly-as-sin rooftop oil cooler scoop will be eliminated (not to mention the drag that thing is causing ~ slowing me down)! Just remember, along with most other members here, I ain't no "Tygaboy"! (IMG:style_emoticons/default/bye1.gif) Tony |
csdilligaf |
Oct 25 2017, 07:26 AM
Member Group: Members Posts: 106 Joined: 18-April 12 From: San Diego CA Member No.: 14,397 Region Association: None |
Tony, Can you tell me a little about the Trans? Cayman/Boxster? and what year? are you running cooling on it as well? And I assume it is holding up?
thanks |
Cracker |
Oct 25 2017, 10:15 AM
It is a 6-speed Boxster- G8620 out of a 2001...we intended to install cooling and have all the equipment/fittings but never felt it was ultimately necessary. We run a max of 25 minute sessions and surely it gets hot but has held up well with over 50-hours to date. My original strategy is they would become throw-away every other year - cooled the jets on retrofitting the case for cooling. It shifts as well now as it did on day number one.
Tony Tony, Can you tell me a little about the Trans? Cayman/Boxster? and what year? are you running cooling on it as well? And I assume it is holding up? thanks |
Lo-Fi Version | Time is now: 25th May 2024 - 10:49 AM |
