914/RS: Re-build and Re-design: Engine and Cooling |
Cracker |
Oct 24 2017, 08:45 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Well, I have never posted a "build" thread in the past - it will serve as my re-build as my car has been running for some time. Something that might be interesting for the H20 folks is a performance based cooling system - oil included.
The silver lining associated with the engine down is I have been intending to make the cooling updates for well over a year now. Its such a PITA I have delayed engagement. LS engines are notorious for running high oil temps on track - GM will tell you it is ok - I believe it is not. Likewise, mid-engine cars have a notoriously difficult time controlling temperatures simply because of the location of the engine and cooling systems. This is exacerbated with additional power. I walked the pits of the Walter Mitty Classic at Road Atlanta last year and took a bunch of pictures. All late-model mid-engined prototypes used Water-to-oil heat exchangers in lieu of oil-to-air. It adds a serious layer of complexity since the coolant now has to carry the burden of dispersing allot of extra energy. That is what I will be updating: all lines, the radiator, shroud addition, coolant distribution chambers, etc. One of the benefits of this new system is the ugly-as-sin rooftop oil cooler scoop will be eliminated (not to mention the drag that thing is causing ~ slowing me down)! Just remember, along with most other members here, I ain't no "Tygaboy"! (IMG:style_emoticons/default/bye1.gif) Tony |
Cracker |
Oct 25 2017, 06:09 AM
This will be very slow moving...especially the cooling mods. The engine should be on its way to Houston by early next week. The shop is not mine (jfyi) - just a good friend who kindly allows me to invade his retirement space and time when a lift is needed.
FWIW: I decided to run DOT approved braided hydraulic lines that were built to my specifications. Since this is a "build thread" I will retroactively share what I compiled. Due to the speeds and performance I expected from this car - I wanted to KNOW everything was as good as it could be. I had a heavy equipment manufacturer (CAT's and such) execute it - each run is coated in a different color sheath (front, rear, clutch). I do not have a single "adapter" in my system - all are direct connections. The clutch line terminates at the MC on one side into the slave cylinder on the other. Tony |
jd74914 |
Oct 25 2017, 11:39 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
FWIW: I decided to run DOT approved braided hydraulic lines that were built to my specifications...I had a heavy equipment manufacturer (CAT's and such) execute it - each run is coated in a different color sheath (front, rear, clutch). I do not have a single "adapter" in my system - all are direct connections. The clutch line terminates at the MC on one side into the slave cylinder on the other. Very cool Tony! Eliminating all adapters is awesome and really quite impressive! (IMG:style_emoticons/default/beerchug.gif) The last racecar had custom lines made by BMRS with correct end fittings as well as integral hard line sections and it was a dream to assemble. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:23 PM |
