914/RS: Re-build and Re-design: Engine and Cooling |
Cracker |
Oct 24 2017, 08:45 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Well, I have never posted a "build" thread in the past - it will serve as my re-build as my car has been running for some time. Something that might be interesting for the H20 folks is a performance based cooling system - oil included.
The silver lining associated with the engine down is I have been intending to make the cooling updates for well over a year now. Its such a PITA I have delayed engagement. LS engines are notorious for running high oil temps on track - GM will tell you it is ok - I believe it is not. Likewise, mid-engine cars have a notoriously difficult time controlling temperatures simply because of the location of the engine and cooling systems. This is exacerbated with additional power. I walked the pits of the Walter Mitty Classic at Road Atlanta last year and took a bunch of pictures. All late-model mid-engined prototypes used Water-to-oil heat exchangers in lieu of oil-to-air. It adds a serious layer of complexity since the coolant now has to carry the burden of dispersing allot of extra energy. That is what I will be updating: all lines, the radiator, shroud addition, coolant distribution chambers, etc. One of the benefits of this new system is the ugly-as-sin rooftop oil cooler scoop will be eliminated (not to mention the drag that thing is causing ~ slowing me down)! Just remember, along with most other members here, I ain't no "Tygaboy"! (IMG:style_emoticons/default/bye1.gif) Tony |
Cracker |
Oct 27 2017, 06:26 PM
Worn - The water to oil heat exchangers are more efficient...a unit measuring roughly a foot long (like my cooler) has the equivalent capacity of a 40-row oil to air cooler. The other benefit is what was pointed out in the last post - it is far easier to plumb oil to a cooler located in the rear of the chassis than to the front. All of this improved energy loss doesn't come free...my entire cooling system from lines, junction boxes, radiator and an improved shroud is all being replaced.
Another big difference between the two systems is the oil being cooled will be off of the scavenge circuit - not the pressure side. It will move slowly enough to give the cooler/coolant a better chance to pull the heat from the oil. I will probably then pass either the coolant or the oil through an liquid to air cooler with a fan pack after the first cooler. The coolant will rejoin the engines heading towards the radiator - the oil will then go the dry sump tank waiting to be sucked into the engine. I do not pretend for a moment to know the scientific explanations or basis but having gone through what doesn't work - I have learned quite a bit. Thanks for the thoughts... Tony |
Chris914n6 |
Oct 28 2017, 01:31 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Another big difference between the two systems is the oil being cooled will be off of the scavenge circuit - not the pressure side. It will move slowly enough to give the cooler/coolant a better chance to pull the heat from the oil. I will probably then pass either the coolant or the oil through an liquid to air cooler with a fan pack after the first cooler. The coolant will rejoin the engines heading towards the radiator - the oil will then go the dry sump tank waiting to be sucked into the engine. Won't matter as the volume will be the same. "Slower" would be a higher capacity heat exchanger, as it stays in the cooler longer. Worn - The water to oil heat exchangers are more efficient...a unit measuring roughly a foot long (like my cooler) has the equivalent capacity of a 40-row oil to air cooler. The other benefit is what was pointed out in the last post - it is far easier to plumb oil to a cooler located in the rear of the chassis than to the front. All of this improved energy loss doesn't come free...my entire cooling system from lines, junction boxes, radiator and an improved shroud is all being replaced. The amount of heat being removed will still be the same, doesn't matter if it is transferred by water or oil. Since you hinted it was running hotter than you would like I'd focus on the radiator and leave the second cooler out until you find the radiator insufficient. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:32 PM |
