Stock Tire Diameter |
mmascari |
Oct 25 2017, 11:50 AM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Can someone please tell me what the stock tire diameter is? I read it somewhere but can't find it.
Also if I run 16" wheels what is the typical tire size that would put it at that same diameter? (50/55/60 series tire) I want to keep the gearing/speedo/odometer accurate. |
dcecc1968 |
Oct 25 2017, 12:21 PM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
Try this link. I couldn't get it to work because my java is out of date, but it used to work.
http://www.914world.com/specs/tirecalc.php |
Elliot Cannon |
Oct 25 2017, 12:26 PM
25 inches??????
Racer |
Oct 25 2017, 02:23 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
its about 25"..
A 155/80-15 was 24.8" A 165/80-15 was 25.4" A 185/70-15 was 25.2" A 205/55-16 is 24.9" * of course, you assume your speedo was "accurate" to begin with. Most of the time they register a little high compared to modern GPS systems. Here's a calculator for you: https://tiresize.com/calculator/ |
mmascari |
Oct 25 2017, 02:55 PM
its about 25".. A 155/80-15 was 24.8" A 165/80-15 was 25.4" A 185/70-15 was 25.2" A 205/55-16 is 24.9" * of course, you assume your speedo was "accurate" to begin with. Most of the time they register a little high compared to modern GPS systems. Here's a calculator for you: https://tiresize.com/calculator/ Awesome thanks! I guess I will have to buy new tires because I have 50 series. I want to be able to cruise on the freeway without the revs being high |
Racer |
Oct 25 2017, 03:52 PM
A 205-50-16? its only 24.2" or then again you might not notice as its not a huge difference. You might notice improved acceleration. Using the calculator, only 30 revs/mile more than a 205-55-16. I don't think you should worry about it imho. Then again, I've run everything from a 165/80-15 to a 185/70-15 to a 195/60-15 to a 205/50-15 to a 195/50-15 and even a 195/60-14. Only the 195/50-15 was truly horrible on the highway. The rest were/are all quite reasonable.
porschetub |
Oct 25 2017, 10:57 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Running 205/50 very close % wise,good width ,decent sidewall height but won't ride anything like the original....
DRPHIL914 |
Oct 26 2017, 08:47 AM
its about 25".. A 155/80-15 was 24.8" A 165/80-15 was 25.4" A 185/70-15 was 25.2" A 205/55-16 is 24.9" * of course, you assume your speedo was "accurate" to begin with. Most of the time they register a little high compared to modern GPS systems. Here's a calculator for you: https://tiresize.com/calculator/ I'm running 205/55 16 and my Speedometer is off by 5mph, and calculated this to be one size too big- a 205/50 would be 24.2 and would be right on according to the calulators. - maybe my speedo is off? the car had really small tires on empi 15" wheels when I bought it and it might be that the p.o. regeared the speedo. |
Racer |
Oct 26 2017, 02:12 PM
Its a bit unlikely someone re-geared the speedo... to much of a hassle imho. Glad your on the path to a tire size you want!
larryM |
Oct 28 2017, 08:58 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
use this calculator http://www.rimsntires.com/specspro.jsp i run 225-50x16 on 7's, and they are almost perfect match to the oem 185-70x15's |
Lo-Fi Version | Time is now: 17th May 2024 - 02:48 PM |
