Looking for Replacement 2.0 Injectors, For 7 of 9 |
rick 918-S |
Oct 25 2017, 08:43 PM
Hey nice rack! -Celette Group: Members Posts: 20,463 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Got a call from Dennis. Stated he had a clutch cable issue. He had it repaired but then was told he had a cracked injector. The shop did a search and located an injector but it was like $ 200.00. (IMG:style_emoticons/default/WTF.gif)
I do not know the source the shop used to get that price but $ 200.00 seems really high. Any good source for replacement injectors? Dennis is looking for a new injector source. |
JeffBowlsby |
Oct 25 2017, 11:16 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Search on these PN
rjames |
Oct 25 2017, 11:33 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Slim pickings out there. I could only find a few listings for compatible 2.0 injectors. All but one was out of country, and the one I found in the U.S. had a $300 price tag. (IMG:style_emoticons/default/blink.gif)
DRPHIL914 |
Oct 26 2017, 06:57 AM
I have all my original that were sent out and cleaned and flow tested perfect so once I get my motor pulled I might be willing to part with the set of 4 that I have in the car now- they are only 3 years old or so, I got them from Otto, spoke to him on the phone the day I ordered them- they were part of a lot he bought from bosch before they quit making them I believe. it might be a few weeks before I can get at them- I do hesitate to sell them all just in case I have one go bad too- so I have not decided whether or not I would sell just one or the matching set of 4.
Send me a PM Rick if you want to discuss. Phil |
914Sixer |
Oct 26 2017, 08:03 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
$200 sounds about right unfortunately.
Tom_T |
Oct 26 2017, 10:02 AM
Rick,
The only 2 sources that I know of for the original NOS 2.0 injectors are AA & HPH, & both were about $150-200-ish last I saw, but I don't know their current prices. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
MarkV |
Oct 26 2017, 12:22 PM
Don't know if they have them in stock:
https://www.fiveomotorsport.com/10399-36lbs-hoses-clamps wrong part 034? |
914Sixer |
Oct 26 2017, 01:31 PM
043 is on Jeff's list above.
Jonathan Livesay |
Oct 26 2017, 04:19 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
914Sixer |
Oct 26 2017, 07:47 PM
I spent an hour checking out some of my sources. I even tried ebay overseas in several countries. Seems there are NO Bosch injectors available thru parts dealers I could find. Does some one have the inside to connect with Bosch Classic? You have to be a dealer.
GB is no longer doing refurbished. |
914_teener |
Oct 27 2017, 04:26 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Don't know if they have them in stock: https://www.fiveomotorsport.com/10399-36lbs-hoses-clamps wrong part 034? I just talked to them.....they have the 038 spec... In srock. They are on OC in Cali but I believe they are remauf. $85 EA |
JeffBowlsby |
Oct 27 2017, 06:13 PM
Montreal914 |
Oct 27 2017, 09:13 PM
Senior Member Group: Members Posts: 1,562 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Don't know if they have them in stock: https://www.fiveomotorsport.com/10399-36lbs-hoses-clamps wrong part 034? I just talked to them.....they have the 038 spec... In srock. They are on OC in Cali but I believe they are remauf. $85 EA 038 seems to be identical to 019 in Bowlsby's chart, (IMG:style_emoticons/default/confused24.gif) Any differences between the 73-74 2.0 and 75-76 2.0 injectors? |
914_teener |
Oct 28 2017, 08:55 AM
Don't know if they have them in stock: https://www.fiveomotorsport.com/10399-36lbs-hoses-clamps wrong part 034? I just talked to them.....they have the 038 spec... In srock. They are on OC in Cali but I believe they are remauf. $85 EA 038 seems to be identical to 019 in Bowlsby's chart, (IMG:style_emoticons/default/confused24.gif) Any differences between the 73-74 2.0 and 75-76 2.0 injectors? I think the latency period is slightly different......probably for emissions. |
DM_2000 |
Oct 28 2017, 05:50 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
Did 75-6 get lock on electrical connectors rather than the rubber boot type?
speedy914 |
Oct 28 2017, 06:22 PM
Newbie Group: Members Posts: 14 Joined: 27-September 07 From: Delaware Member No.: 8,166 |
No. 75-76 still the same connector. I very recently bought 4 injectors from RockAuto.
Not Bosch of course, but they do seem to work fine. Car is stock and runs great. (there are some NOS one out there, might have seem some at Aase maybe? |
DM_2000 |
Oct 29 2017, 07:09 AM
I've used this to search for specs on 90's Bosch parts http://www.bosch-automotive-catalog.com/en/product-search |
MartyYeoman |
Oct 29 2017, 11:38 AM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Did you try www.fuelinjectioncorp.com
Lo-Fi Version | Time is now: 20th May 2024 - 09:21 PM |
