What is the part on the manifold with two wires?, Looking down from driver's side at 7:o'clock..goes into plenum? |
second wind |
Oct 26 2017, 10:59 PM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey Guys....anyone awake....if you look down onto the throttle body from driver's side, there is a device that has a two wire electrical plug that goes into the plenum or manifold if you wish that is under the throttle body. Mine has the wires ripped off and car has not run for two weeks.....what do you suppose this is? It is about 7: o'clock on the dial if the throttle body is the clock.....below the throttle body though but attaches into the manifold......do tell? Thank you!
gg |
BeatNavy |
Oct 27 2017, 04:27 AM
Hey Guys....anyone awake....if you look down onto the throttle body from driver's side, there is a device that has a two wire electrical plug that goes into the plenum or manifold if you wish that is under the throttle body. Mine has the wires ripped off and car has not run for two weeks.....what do you suppose this is? It is about 7: o'clock on the dial if the throttle body is the clock.....below the throttle body though but attaches into the manifold......do tell? Thank you! gg T1 (ambient air temp) sensor? I'm guessing based on description and without pic. If it's disconnected, your car will run a little richer (when it's running). In and of itself a bad or disconnected T1 shouldn't keep the car from running decent... Picture would be helpful. Also assume you actually ARE running D-Jet... |
TheCabinetmaker |
Oct 27 2017, 06:12 AM
Yes. A picture would help
GregAmy |
Oct 27 2017, 07:17 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Aux Air Regulator?
Cold Start Valve? Neither one would keep the car from running. |
TheCabinetmaker |
Oct 27 2017, 07:40 AM
If I saw a plug with no wires, and two wires that have "been ripped out", I'd just stick them back in. Not rocket surgery!
Olympic 914 |
Oct 27 2017, 08:21 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Probably this...
Intake temp sensor. |
second wind |
Oct 27 2017, 10:00 AM
Probably this... Intake temp sensor. Thank you, but that is not it. I will try picture now that it is daytime. Relative to your picture....opposite side and UNDER the edge of the manifold.....kind of a big sucker with an entry into the manifold that is like a pipe. I'd best get picture. gg |
second wind |
Oct 27 2017, 10:56 AM
Probably this... Intake temp sensor. Thank you, but that is not it. I will try picture now that it is daytime. Relative to your picture....opposite side and UNDER the edge of the manifold.....kind of a big sucker with an entry into the manifold that is like a pipe. I'd best get picture. gg This is it.... Attached image(s) |
brownaar |
Oct 27 2017, 11:00 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Cold start valve/injector.
GregAmy |
Oct 27 2017, 11:50 AM
Oct 27 2017, 04:17 PM
I unplugged mine, and rerouted the fuel lines to bypass it because at the time a new cold start injector was not available. Mine leaked enough to make my car run really rich all the time. I found little to no impact on cold starting in New England, and at that time I did drive it year round.
Lo-Fi Version | Time is now: 17th May 2024 - 02:11 PM |
