Garage Find Restoration |
krazykonrad |
Oct 28 2017, 08:23 AM
Senior Member Group: Members Posts: 1,125 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
krazykonrad |
Apr 7 2018, 04:01 PM
No sealant. Old school technique is to clean everything up really good, and lap the barrels to the case with valve lapping compound, but you've got to have the head studs off, which to me isn't worth the trouble. These cases have been know to have trouble with the barrel (cylinder) registers (mounting surface) sinking and causing leaks. You might want to lay a known precise straight edge across the cylinder registers and shine a light across to see if it's nice and flat, if it's not you could have troubles Thanks Perry! Piston rings are going together just fine. Maybe by the time everyone else is driving space ships, I’ll have this thing back on the road. |
Lo-Fi Version | Time is now: 13th May 2024 - 05:57 AM |
