Garage Find Restoration |
krazykonrad |
Apr 5 2018, 05:24 PM
Senior Member Group: Members Posts: 1,124 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
The next step is putting the jugs onto the case. I have shims in between, so should I use any sealant or should I just make sure the mating surfaces are good and clean?
Thanks, Konrad |
Ed_Turbo |
Apr 6 2018, 02:14 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
IronHillRestorations |
Apr 6 2018, 05:03 PM
No sealant. Old school technique is to clean everything up really good, and lap the barrels to the case with valve lapping compound, but you've got to have the head studs off, which to me isn't worth the trouble.
These cases have been know to have trouble with the barrel (cylinder) registers (mounting surface) sinking and causing leaks. You might want to lay a known precise straight edge across the cylinder registers and shine a light across to see if it's nice and flat, if it's not you could have troubles |
krazykonrad |
Apr 7 2018, 04:01 PM
No sealant. Old school technique is to clean everything up really good, and lap the barrels to the case with valve lapping compound, but you've got to have the head studs off, which to me isn't worth the trouble. These cases have been know to have trouble with the barrel (cylinder) registers (mounting surface) sinking and causing leaks. You might want to lay a known precise straight edge across the cylinder registers and shine a light across to see if it's nice and flat, if it's not you could have troubles Thanks Perry! Piston rings are going together just fine. Maybe by the time everyone else is driving space ships, I’ll have this thing back on the road. |
krazykonrad |
May 5 2019, 04:46 PM
krazykonrad |
Jan 9 2021, 02:35 PM
A huge thanks to Perry Kiehl at Iron Hill Restorations for the head nuts. I forgot to take a picture of them before I put them on, but you'll see how nice and shiny they are in a minute.
krazykonrad |
Jan 9 2021, 02:38 PM
And a big thank you to Kenn Young at Hennessy Porsche in Atlanta for the head washers.
krazykonrad |
Jan 9 2021, 02:39 PM
It's starting to come together...
krazykonrad |
Jan 9 2021, 02:40 PM
The head nuts look great! I'll torque them up later on.
930cabman |
Jan 9 2021, 02:47 PM
Advanced Member Group: Members Posts: 3,001 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Great opening pic with kids stuff hiding the sports machine, and better to see this project moving. Keep up the energy and you will be tooling around with the kids before you know it
Lo-Fi Version | Time is now: 28th April 2024 - 08:59 AM |
