Rebel Racing front RSR coil overs instead of torsion bars?, Who’s tried them? |
Steve |
Nov 6 2017, 08:23 AM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Rebel Racing RSR coil overs instead of torsion bars.
Who’s tried them? http://www.rebelracingproducts.com/914products.html |
Nov 6 2017, 12:46 PM
Resident German Group: Admin Posts: 41,637 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Rebel Racing RSR coil overs instead of torsion bars. Who’s tried them? http://www.rebelracingproducts.com/914products.html That seems surprisingly affordable ... (IMG:style_emoticons/default/idea.gif) |
Steve |
Nov 6 2017, 12:50 PM
Good reviews on Pelican. Rebel only has a bilstein option versu Elephant also has a Boge strut option.
raynekat |
Nov 6 2017, 01:14 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
What is the car's intended use?
If a daily driver, you need to make sure you can get a soft enough spring. If mostly a track car, then have at it. |
Steve |
Nov 6 2017, 02:34 PM
What is the car's intended use? If a daily driver, you need to make sure you can get a soft enough spring. If mostly a track car, then have at it. I’m looking for feed back who have tried it, not the obvious. Both options support multiple spring rates for street and track. Feedback from other sites include. -more spring options -rides like a modern car or later 911 with front springs. But these are 911 sites... I’m looking for 914 references. |
phillstek |
Nov 6 2017, 03:19 PM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Don't know about RR coil overs as I have ERs level 3 on my car and I love them. I used to have turbo struts and standard torsion bars and the car was lowered quite a bit. Bump steer was horrendous with that set up but with the ER set up it's no longer an issue. They are very firm and bang pretty loud when hitting lane markers as I also have the solid mounts at the top. Car steers and corners flat with instant turn in response but probably should have chosen level 2 as these would be better on the street.
Hope that's of some help. |
LowBridge |
Nov 6 2017, 04:08 PM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
I have the RR coilovers on the rear of my 914 and I really enjoy them. I believe it offers more options when trying to balance the corners. the only thing I would do different is also get the helper springs, it just makes things easier when you are jacking the car up and down.
Attached thumbnail(s) |
tygaboy |
Nov 6 2017, 04:38 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Don't know about RR coil overs as I have ERs level 3 on my car and I love them. I used to have turbo struts and standard torsion bars and the car was lowered quite a bit. Bump steer was horrendous with that set up but with the ER set up it's no longer an issue. They are very firm and bang pretty loud when hitting lane markers as I also have the solid mounts at the top. Car steers and corners flat with instant turn in response but probably should have chosen level 2 as these would be better on the street. Hope that's of some help. Great to hear as I've been talking with Elephant about their front coil over set up. Still not sure if I'd go Level 1 or Level 2. Question: I have the Elephant Quick Change camber plates so I'm curious: Do you think your "lane marker bang" is related mostly to the Level 3 valving vs. the solid top mounts? Thanks in advance... |
Nov 6 2017, 05:03 PM
I have heard that it is a good idea to reinforce the strut towers when changing any torsion-bar Porsche to coilovers. No direct data myself.
--DD |
Larmo63 |
Nov 6 2017, 05:30 PM
Raised spindles, bump steer kit, and coil-overs will be expensive. You might get new shocks too and some new goodies for the camber plates. I've only looked at both Elephant and Rebel Racing's websites on this very subject about a thousand times.
Reinforcing shock towers is getting into kooky (but cool) territory. I know it's only money, but it seems like one thing leads to another...."while I was in there" |
phillstek |
Nov 6 2017, 06:56 PM
Don't know about RR coil overs as I have ERs level 3 on my car and I love them. I used to have turbo struts and standard torsion bars and the car was lowered quite a bit. Bump steer was horrendous with that set up but with the ER set up it's no longer an issue. They are very firm and bang pretty loud when hitting lane markers as I also have the solid mounts at the top. Car steers and corners flat with instant turn in response but probably should have chosen level 2 as these would be better on the street. Hope that's of some help. Great to hear as I've been talking with Elephant about their front coil over set up. Still not sure if I'd go Level 1 or Level 2. Question: I have the Elephant Quick Change camber plates so I'm curious: Do you think your "lane marker bang" is related mostly to the Level 3 valving vs. the solid top mounts? Definitely the solid camber plates making the noise. 'I have heard that it is a good idea to reinforce the strut towers when changing any torsion-bar Porsche to coilovers. No direct data myself’ You mentioned this possibility when I posted about these some time ago. They’ve been on the car for over 10,000 miles now and I check them regularly. Car is driven over shitty Aussie roads including dirt, so far there is absolutely no sign of stress fractures or metal fatigue. Attached image(s) |
jim_hoyland |
Nov 6 2017, 08:22 PM
Get that VIN ? Group: Members Posts: 9,294 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I am looking at doing this too.....
Montreal914 |
Nov 6 2017, 08:50 PM
Senior Member Group: Members Posts: 1,558 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
OT, but looking at their catalog, they also have the aluminum Brembo (S equivalent) front Calipers. (IMG:style_emoticons/default/smile.gif)
gms |
Nov 6 2017, 10:35 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I have 935 coil over struts on the race car and love them!
euro911 |
Nov 7 2017, 02:03 AM
erwan914 |
Nov 7 2017, 04:49 AM
Member Group: Members Posts: 120 Joined: 22-August 12 From: france Member No.: 14,834 Region Association: None |
Steve |
Nov 7 2017, 08:14 AM
Thanks for the feedback.
Are you guys still running torsion bars with the springs? If you run springs without torsion bars, did you do anything special with the “A” arms? I noticed one guy on pelican still installed the RSR $350.00 bushings. |
infraredcalvin |
Nov 7 2017, 08:49 AM
Distracted Member Group: Members Posts: 1,515 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I’ve never understood why people get coilovers and still use torsion bars. It’s extra weight (albeit lower on the car) coil over ends up being a helper spring... the 930 guys I’ve seen that stared with a combo have quickly changed to coilover only.
If you’re going through the expense of coilovers you should address all the movement components in the assembly - weather its rubber, poly or other is up to you. |
infraredcalvin |
Nov 7 2017, 08:52 AM
gms |
Nov 7 2017, 08:44 PM
If you’re going through the expense of coilovers you should address all the movement components in the assembly - weather its rubber, poly or other is up to you. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 03:52 PM |
