QUOTE(tygaboy @ Nov 7 2017, 09:38 AM)
Don't know about RR coil overs as I have ERs level 3 on my car and I love them. I used to have turbo struts and standard torsion bars and the car was lowered quite a bit. Bump steer was horrendous with that set up but with the ER set up it's no longer an issue. They are very firm and bang pretty loud when hitting lane markers as I also have the solid mounts at the top. Car steers and corners flat with instant turn in response but probably should have chosen level 2 as these would be better on the street.
Hope that's of some help.
Great to hear as I've been talking with Elephant about their front coil over set up. Still not sure if I'd go Level 1 or Level 2.
Question: I have the Elephant Quick Change camber plates so I'm curious: Do you think your "lane marker bang" is related mostly to the Level 3 valving vs. the solid top mounts?
Definitely the solid camber plates making the noise.
'I have heard that it is a good idea to reinforce the strut towers when changing any torsion-bar Porsche to coilovers. No direct data myself’
You mentioned this possibility when I posted about these some time ago. They’ve been on the car for over 10,000 miles now and I check them regularly. Car is driven over shitty Aussie roads including dirt, so far there is absolutely no sign of stress fractures or metal fatigue.
