just ordered brass/copper shift bushing, from GPR- anyone using these? |
xsboost90 |
May 25 2005, 12:01 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
pelican only had the plastic ones and it was gonna be more for shipping than for the part! Called GPR and they are sending it out today. Do these bushings stiffen up the shifter much and am i supposed to grease them at all? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
anybody like them? do they taste good? fashionable? |
Rouser |
May 25 2005, 05:17 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
If you're talking about the bushing at the tranny end, I've been using one and it does the job.
Most of the time the mount back there is oblonged out due to the bar sagging and the plastic bushing moving back-and-forth, which happened to be my case. I purchased the bronze bushing from GPR (with c-clip) and JB Weld'd it in place, which makes for a much more solid mount. Fashionable? I'd recommend it over the plastic/Teflon bushing, if only because it'll last a whole lot longer. And yes, you should grease ALL your bushings, regardless of the "Teflon" claims. Attached image(s) |
Rouser |
qwerty
Red-Beard |
May 25 2005, 06:07 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
You need to clean that tranny....
Allan |
May 25 2005, 06:14 PM
I didn't even know they had the brass bushings... Anyway, I replaced all of mine with the teflon ones except the u-joint on the rear shift rod.
My Motto: If it moves, lube it. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Bleyseng |
May 25 2005, 06:22 PM
Duh, a nice cheap upgrade
JeffBowlsby |
May 25 2005, 06:28 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hey Roy...whydja JB weld it in...? ALL Bushings wear out and they eventually need replacement. With the C-clip it doesnt move.
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Rotary'14 |
May 25 2005, 07:06 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Hey, I want one of those too,, I looked at GPR's site and I couldn't find that bushing, can anybody give me a direct link to it?
Thanks, (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) |
Rouser |
May 25 2005, 08:04 PM
Oh yes, it (still) does ... It's the hole on the rear tranny shifter mount that the rod passes through that gets ovaled out, especially when a worn rear bushing is left to bang up-down-'n-around back there. You stick a new (plastic) bushing back there and there's enough play to sabotage your efforts for clean shifting. That C-clip only retains the bushing, it doesn't center it. I wouldn't JB Weld a plastic bushing in there; the brass one is well worth it. |
Korijo |
May 25 2005, 09:32 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) cant find it. how much? i vaguely remember stromberg selling a bronze ball-cup bushing... anybody have one? |
xsboost90 |
May 25 2005, 09:46 PM
no they didnt list it, so i called and he pulled it up right away. 26 plus shipping like $32. - alittle more than the $8.50 for the plastic one but.... I'll grease it and go! My tranny is not oblonged, never seen one that bad, my bushing is just alittle loose, trying to stiffen it up as much as possible.
tat2dphreak |
May 25 2005, 09:50 PM
I wish someone would have had these last year when I installed the tranny and engine... oh well, when the plastic wears out again, I'l get these...
do they have a early-late firewall converter bushing? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 01:35 PM |
