90o AN fitting to the stock cooler?, for the /6 conversion... |
DougC |
May 25 2005, 01:53 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
I have AN hose that I'll be running from the 914/6 oil tank to the (engine mounted) oil cooler. I know that the cooler has to be modified but since I have a simple weld-on straight AN adapter, couldn't I just weld that adapter onto the blank end of the cooler's pipe then use a 90 degree AN fitting to attach it to the hose? I mean is there enough room to do that? Would the cooler's pipe (which has no threads) have to be shortened, by how much? Would a 45 degree fitting work..I already have one of those? I haven't seen anyone do it this way, only seen 90 degree fittings welded to the cooler's pipe..any pics?
Doug C |
Joe Bob |
May 26 2005, 09:30 AM
Went to Pegasus...din't see the "T" but did see a quick disconnect that might have some possibilities...if yer into gee wiz stuff that no one ever sees.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Quick D |
brant |
May 26 2005, 11:53 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
hey Doug,
I found this pic too and I thought it had a better view point or perspective.. of the space available: Attached thumbnail(s) |
DougC |
May 26 2005, 01:03 PM
Yes, that pic helps and I'm saving it for future reference. I looked at pegasus' website before I posted this thread and didn't see the drain fitting.. may have better luck just calling them though, which I'll do eventually.
Mike, that 911 hose doesn't crimp itself closed at the 90 degree turn? Got a picture? Doug C |
Joe Bob |
May 26 2005, 02:28 PM
I can take pics later but the hose comes straight down without any bends....I cut the pipe a bit further back towards the cooler.
Lo-Fi Version | Time is now: 19th May 2024 - 07:56 PM |
