Windshield to Dash Seal '70, any leads on OEM type w/ metal grips |
76-914 |
Nov 11 2017, 07:49 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I have the one w/o the metal grips but it wants to walk. Any leads?
Mikey914 |
Nov 16 2017, 07:18 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I resorted to using a dental pic to get it all off. The new seal was made to cut the notch for the pillar trim it goes against, then cut it about 1/4" longer with a notch on the other side. Put the corners in 1st and try to over center. Trim a little at a time til it works. It is difficult to remove once over centered, but catch the edge and you can pull it all out in one piece. Best reason to use my seal is it WILL come out all in one piece. Much less swearing.
Lo-Fi Version | Time is now: 15th May 2024 - 05:10 AM |
