gas lines and acc to carbs, pics??? |
firstknight13 |
May 25 2005, 08:38 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
hey you guys!! got any pics of your gas lines to carbs??? also accelorater cable set up?? thanks (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
ArtechnikA |
May 26 2005, 06:33 AM
fuel line
SGB |
May 26 2005, 07:13 AM
SS fuel; lines with simple Y-fitting, SS band bent into U-shape and bolted to case for acc cable end.
Attached thumbnail(s) |
Trekkor |
May 26 2005, 08:10 AM
braided lines with dual outlet reg
rhodyguy |
May 26 2005, 09:08 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
hot ticket for the linkage. Triad. even comes with a throttle cable holder, powdercoated, ready to go. maintains carb dial in superbly.
k Attached image(s) |
firstknight13 |
May 26 2005, 07:56 PM
yes the triad looks good.how many of you guys use a return spring on the throttle?? also are the ss lines hard to do??? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
May 26 2005, 08:03 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
fuel lines: low pressure (3.5) rotary fuel pump from cb performance (very nice!), from there to a "T" then one line to each carb. return line plugged ...
cable bracket: see pic below ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy Attached image(s) |
firstknight13 |
May 26 2005, 08:08 PM
NICE engine compartment andy where did you get the oil blowby box??? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
May 26 2005, 08:48 PM
schanks! puke box is also from cb performance ... (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) Andy |
SGB |
May 26 2005, 08:56 PM
for return springs, I wanted a little assurance, so I used a spring on each carb (pulling up on the throttle shaft from the bottom of the air cleaner) and a third , longer-"softer" spring from the throttle cable barrel nut to the rear firewall. I've noticed that some system have the linkage toward the back (like mine) and some (like the triad) operating the carbs with the linkage toward the front firewall. I dunno which are better. I know I replaced my 20 yo weltmiester with the CB's aluminum setup specifically for 914s and it made a great improvement- got a whole package- linkage, manifolds, velocity stacks, air cleaners and they are apparently all tuned together- its really cool the way everything hooks up and goes bzzzz-bzzzz-bzzz instead of the previous UPS truck sound.... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Lo-Fi Version | Time is now: 8th May 2024 - 02:26 PM |
