Shift Pattern, What to do if your knob doesn't have it. |
7TPorsh |
Nov 14 2017, 05:41 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Are there any shift pattern "plates" available that display our 914 shift pattern?
I have the 917 wood knob...In the rare event i may leave my car with a valet or let a hot chick try to drive it they don't know the pattern. Maybe somebody can create a small plate (group buy?) with an engraved pattern that can be mounted to the dash? Any ideas? |
thelogo |
Nov 15 2017, 11:38 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I dont think these guys needed the shift knob pattern
So i guess i dont either But if you were an instrument rated pilot ? Anybody Could you fly a small plane with out all the labels On the guages . Im sure you could , except fuel guage |
Elliot Cannon |
Nov 16 2017, 05:43 PM
I dont think these guys needed the shift knob pattern So i guess i dont either But if you were an instrument rated pilot ? Anybody Could you fly a small plane with out all the labels On the guages . Im sure you could , except fuel guage Years ago, aircraft instrument panels were standardized to what was eventually called a "six Pack". You could go from one model airplane to another and still pretty much expect the flight instruments to be in the same position relative to each other. Even the new "glass cockpits" have the flight instruments in the same configuration. My airplane doesn't have any flight instruments 'cause nobody pays me to fly in bad weather anymore. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/smoke.gif) No labels needed. (IMG:style_emoticons/default/smile.gif) Attached image(s) |
thelogo |
Nov 16 2017, 11:32 PM
So to be instruments rated
You mainly just use the 6pack And i thought even if you fly in good weather or visual flight Rules That the fog could roll in And you will need instrument flying to survive And was roy hollidays plane a bad design since it encourages A pilot to push or fly to the edge of the envelope more |
Coondog |
Nov 17 2017, 06:12 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
And was roy hollidays plane a bad design since it encourages A pilot to push or fly to the edge of the envelope more Just like JFK Jr. Mr. Halladay was a very low hour pilot flying a airplane that was beyond there skill level which in both cases over confidence led to fatal decisions. JFK not being IFR rated to which his airplane was equipped for and who was flying at the limits of if not beyond VFR. Roy Halladay was show boating going from several 100 feet above the water down to 5 feet above the water. |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:15 PM |
