Making custom gauge faces? |
Nov 17 2017, 07:36 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Well that certainly explains a lot. If there is someone who is willing to do the graphics and share, it seems like this could be printed at home.
burton73 |
Nov 17 2017, 07:40 PM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Well that certainly explains a lot. If there is someone who is willing to do the graphics and share, it seems like this could be printed at home. Yes. The hard part is getting the film. I just bouight 45 more 1 8.5 x 11 sheets on EBay at $.50 per sheet delivered. . I have had in the past had to buy it from Germany or France. Like I said it is all over the world. I guess it was not a big item for Epson. Bob B |
burton73 |
Nov 17 2017, 07:43 PM
My inkjet is somewhat clogged today and not printing 100% so I could not print out any samples but I know this works well. The blacks are very dark as are the colors. It puts printing on paper to shame. Super crisp. Clear.
Bob B (IMG:style_emoticons/default/cheer.gif) |
914forme |
Nov 17 2017, 08:39 PM
Yes Bob thank you for sharing this idea. I have another way of doing this on an inset, but you use pigmented ink, so not a standard inkjet. Printed on vinyl and then you laminate to cover it. That process shoals last 20-30 years. It is more equipment heavy than Bob's solution.
Mark sharing the files is not hard, I know I have hours in my files and they are still not done to my liking. Also Epson now makes a replacement for the white film. I tis a clear film that lets you print white using one of their $8400 printers and the ink cartridges especially the whites are expensive. Another way of doing this is just printing vinyl stencils and airbrushing them. Long process. But can be done at home still. |
burton73 |
Nov 17 2017, 10:17 PM
Yes Bob thank you for sharing this idea. I have another way of doing this on an inset, but you use pigmented ink, so not a standard inkjet. Printed on vinyl and then you laminate to cover it. That process shoals last 20-30 years. It is more equipment heavy than Bob's solution. Mark sharing the files is not hard, I know I have hours in my files and they are still not done to my liking. Also Epson now makes a replacement for the white film. I tis a clear film that lets you print white using one of their $8400 printers and the ink cartridges especially the whites are expensive. Another way of doing this is just printing vinyl stencils and airbrushing them. Long process. But can be done at home still. Sent you more pictures Bob B |
falcor75 |
Nov 18 2017, 06:58 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I'l contact car-bone and see what they can offer.
I measured the Saab gauge today and it is as follows: 10 ohm: low reserve / empty 22 ohm: start of reserve 47 ohm: 50%, middle of range 100 ohm: 60% 150 ohm: 90% 172 ohm: Max on the scale 200 ohm: needle maxed Then I did the same for the stock 914 gauge and got this: 10 ohm: 90% 22 ohm 70% (just below 3/4) 32 ohm 50% 47 ohm 30% 69 ohm Reserve (needle on the R) So the scales are inverted from eachother, one way around this would be to get a VDO gauge and plunder the mechanism as defianty did. When I bought the gas gauge the seller asked if I wanted a Saab temp gauge aswell for the another $5 so I said sure, its not breaking the bank and he wanted to get rid of them both. So after realizing the scales were inverted I had a small stroke of genius. I started testing the Saab temp gauge in the same way and got this result: 10 ohm: needle pegged on max 22 ohm: end of the red area 47 ohm: 50% middle of scale 100 ohm: start of the green area 200 ohm: 20% of the black area 270 ohm: start of the black area So the temp gauge goes the same way as the stock gauge but with a different resolution. Dig up some old electronics books from university and taddaaa... if I connect a 100 ohm resistor in parallell with the sender I will get a pretty good match in the range of the scale from 50% and below. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 11:17 PM |
