Front sway bar question |
1bad914 |
May 26 2005, 08:38 AM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
Went by my local 914 parts (junk) yard and looked under one of his cars, it had a very differnt front sway bar, the bar was not in the traditional spot running under the gas tank, but was attached to the bottom of the front trunk, the links came up under the a-arms and then attached to the stock location on the arm. They must be fairly new since the main bushings on the bar were urethane. Anyone recognize this configuration, is it better, worse...the main bar does seem larger. I did not have my camera or I would have taken pictures.
Gint |
May 26 2005, 08:53 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Sounds like the under the body 911 bar that some years had. We've discussed here in the past. It's easier to install, probably works as well as a 914 stock bar, but I've seen 914 front trunk floors with stress cracks that resulted from the mounting of that type of bar.
Eric_Shea |
May 26 2005, 09:00 AM
74 plus 911 front suspension. 74-77 were "generally" 18mm. 78 and later were "generally" 20mm. The suspension geometry is rumored to be not as good as the through-body types. I didn't realize it attached to the trunk floor. I thought it was the crossbar... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
1bad914 |
May 26 2005, 09:05 AM
I'll try and take a pic. I have a stock bar and can get this one. The car currently does not have one, I was trying to avoid cutting holes for the stock install, been there done that.
Gint |
May 26 2005, 09:21 AM
You'd rather drill holes in your front trunk floor? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Eric_Shea |
I know, I know but... cut the holes. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
brant |
May 26 2005, 09:24 AM
mmmm.....
holes are guud, kay. (south park) |
Eric_Shea |
May 26 2005, 09:32 AM
Are these things really attached to the trunk floor? Me no likes that at all, at least not without some serious metal work in the way of additional bracing (ala the rear bar). I thought the crossbars had mounting points.
Good point Brant... holes are guuuuuud (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:32 AM |
