Are all FI trigger points created equal?, Will points from a 1.7 work with a 2.0? |
KELTY360 |
Nov 19 2017, 01:39 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I've got an 009 dizzy and want to know if the trigger points are compatible with a stock '75 2.0 dizzy.
rhodyguy |
Nov 20 2017, 01:19 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Confused. Marc, are you talking fi or spark points?
KELTY360 |
Nov 20 2017, 01:32 PM
Confused. Marc, are you talking fi or spark points? Hate to do this to you Kevin, but you might want to read the title of the thread. (IMG:style_emoticons/default/slap.gif) (I never get to use that smiley...feels so good) |
Root_Werks |
Nov 20 2017, 02:21 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Confused. Marc, are you talking fi or spark points? Hate to do this to you Kevin, but you might want to read the title of the thread. (IMG:style_emoticons/default/slap.gif) (I never get to use that smiley...feels so good) If you're going there Marc, your title says FI Trigger points and 009 dizzy's don't have FI trigger points so (IMG:style_emoticons/default/slap.gif) If you are talking spark points, ditch the 011 and get a 002 set used on early 911's with CD boxes. They are heavier springs and larger contact area. They can take a pounding and should drop right into any dizzy that uses the 011 points. If you need FI trigger points, good luck. |
KELTY360 |
Nov 20 2017, 02:37 PM
Confused. Marc, are you talking fi or spark points? Hate to do this to you Kevin, but you might want to read the title of the thread. (IMG:style_emoticons/default/slap.gif) (I never get to use that smiley...feels so good) If you're going there Marc, your title says FI Trigger points and 009 dizzy's don't have FI trigger points so (IMG:style_emoticons/default/slap.gif) If you are talking spark points, ditch the 011 and get a 002 set used on early 911's with CD boxes. They are heavier springs and larger contact area. They can take a pounding and should drop right into any dizzy that uses the 011 points. If you need FI trigger points, good luck. Now I'm confused, Dan. I've got a Bosch dizzy: PN#0 231 174 009 that definitely has FI trigger points. What the hell is it? |
Lo-Fi Version | Time is now: 18th May 2024 - 02:07 PM |
