KELTY360
Nov 19 2017, 01:39 PM
I've got an 009 dizzy and want to know if the trigger points are compatible with a stock '75 2.0 dizzy.
914_teener
Nov 19 2017, 02:26 PM
QUOTE(KELTY360 @ Nov 19 2017, 11:39 AM)
They will fit the stock distributor for both the 1.7 and 2.0 distributors.
Dave_Darling
Nov 19 2017, 04:56 PM
What "009" distributor do you have? There is one that is from a 1.8 liter, and it doesn't have FI trigger points. There is one that is completely aftermarket, and it also doesn't have FI trigger points.
If you have a D-jet distributor (1.7 or 2.0) the trigger points are the same. Also for the D-jet VWs, I believe, and possibly other D-jet cars.
Pics might help as well.
--DD
KELTY360
Nov 19 2017, 05:14 PM
QUOTE(Dave_Darling @ Nov 19 2017, 03:56 PM)
--DD
My 009 is a Bosch unit I got years ago with a '72 parts car. It has trigger points that appear to be in good working condition. Sounds like they are compatible with all D-jet FI.
r_towle
Nov 20 2017, 07:18 AM
As far as I can tell, it’s a binary switch that goes off at 180 degrees
They all look the same to me.
Vw 411
Volvo p1800
Porsche 914
Root_Werks
Nov 20 2017, 08:49 AM
Don't use used points unless your stranded.
Get some "002" points, put them along side the points you remove or the points in the 009 dizzy. You'll see why they are better.
911-602-936-00-M1002
JeffBowlsby
Nov 20 2017, 09:08 AM
Not all DJet trigger points are the same. Benz DJet cars use trigger points that are different than those for 914s and VDubs.
rhodyguy
Nov 20 2017, 01:19 PM
Confused. Marc, are you talking fi or spark points?
KELTY360
Nov 20 2017, 01:32 PM
QUOTE(rhodyguy @ Nov 20 2017, 12:19 PM)
Hate to do this to you Kevin, but you might want to read the title of the thread.
(I never get to use that smiley...feels so good)
Root_Werks
Nov 20 2017, 02:21 PM
QUOTE(KELTY360 @ Nov 20 2017, 11:32 AM)
If you're going there Marc, your title says FI Trigger points and 009 dizzy's don't have FI trigger points so
If you are talking spark points, ditch the 011 and get a 002 set used on early 911's with CD boxes. They are heavier springs and larger contact area. They can take a pounding and should drop right into any dizzy that uses the 011 points.
If you need FI trigger points, good luck.
KELTY360
Nov 20 2017, 02:37 PM
QUOTE(Root_Werks @ Nov 20 2017, 01:21 PM)
Now I'm confused, Dan. I've got a Bosch dizzy: PN#0 231 174 009 that definitely has FI trigger points. What the hell is it?
JeffBowlsby
Nov 20 2017, 02:42 PM
Brad Anders page says that 0231174009 is the Bosch PN, for 039905205 Porsche PN which is the 1973 2.0L dizzy. Its D-Jet.
KELTY360
Nov 20 2017, 02:54 PM
QUOTE(Jeff Bowlsby @ Nov 20 2017, 01:42 PM)
Interesting. This dizzy also has the 039905205 number with a VW logo in front of it.
JeffBowlsby
Nov 20 2017, 03:06 PM
Its normal to have both numbers.
Root_Werks
Nov 20 2017, 03:16 PM
Yep, sorry Marc, thought you were refering to one of the "009" aftermarket angular accerlation dizzy's.
KELTY360
Nov 20 2017, 03:25 PM
QUOTE(Root_Werks @ Nov 20 2017, 02:16 PM)
Think you're getting off that easy?
What are you up to dude?
Root_Werks
Nov 20 2017, 04:31 PM
QUOTE(KELTY360 @ Nov 20 2017, 01:25 PM)
Still no 914, but have my 76's standard FI bug. Mostly fly these days, no time or money for cars anymore. Airplanes are more fun.
Some day, I'd like to get another 914.
rhodyguy
Nov 20 2017, 07:34 PM
Hate to do this to you Marc....As previously noted, the 009 is the common ID for a centrifical advance dist used on carbed cars. That you later added the complete number after the fact eases the confusion. At least on my end. Amazing that the COMPLETE numbers is identical to one in Jeff's post.
