Fuel Pump for Carbs, Fuel Pump |
simonjb |
Nov 20 2017, 09:25 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I was wondering what fuel pump folks are using and like for a Carb conversion. Engine is a 2.0 upgraded to 2.3 with two Weber 44 IDF carbs.
Spoke |
Nov 20 2017, 09:31 AM
Jerry Group: Members Posts: 6,977 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
theer |
Nov 20 2017, 09:35 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Tangerine sells everything you need (see fuel pumps at bottom left):
http://www.tangerineracing.com/stainlessfuellines.htm |
GeorgeRud |
Nov 20 2017, 09:48 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Low pressure Pierburg pump mounted up front by the steering rack.
michael7810 |
Nov 20 2017, 01:29 PM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Tangerine sells everything you need (see fuel pumps at bottom left): http://www.tangerineracing.com/stainlessfuellines.htm I've been using the pump from Tangerine for 3 years now without problem. No pressure regulator needed and is quiet enough that I don't hear it with the engine running. |
porschetub |
Nov 20 2017, 01:35 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Low pressure Carter pump mounted on front crossmember,not too loud, fairly priced and runs well.
I seem to remember the same pump comes from CB performance also. |
SirAndy |
Nov 20 2017, 01:55 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I seem to remember the same pump comes from CB performance also. CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056. http://www.cbperformance.com/product-p/3193.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1511207757.1.jpg) Friends don't let friends use facet pumps ... (IMG:style_emoticons/default/barf.gif) |
Mark Henry |
Nov 20 2017, 04:41 PM
You can buy a PMO fuel pressure regulator and run your existing FI fuel pump.
forrestkhaag |
Nov 20 2017, 05:49 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Sir Andy's pump as illustrated is the one I have been running on my 3.0-6 without an issue and the pressure regulator and gauge shows consistent pressure at 2.5-3.
sportlicherFahrer |
Nov 20 2017, 06:14 PM
Nothing to see here. Group: Members Posts: 1,072 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Running that same Carter pump from CB Performance on mine as well. Constant correct pressure. I would recommend removing the supplied filter and either relocating it, or replacing the clamps at a minimum. I've seen a couple of them leak at those fittings fresh out of the packaging.
SirAndy |
Nov 20 2017, 06:45 PM
And i forgot, whatever you do, please don't hack into your wiring harness!
You can mount and power the low pressure pump in the same spot as the FI pump and even use the same wires, fuses and relays without ever cutting anything. http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php (IMG:style_emoticons/default/shades.gif) |
simonjb |
Nov 20 2017, 08:26 PM
Thanks guys !
porschetub |
Nov 20 2017, 10:21 PM
I seem to remember the same pump comes from CB performance also. CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056. http://www.cbperformance.com/product-p/3193.htm Friends don't let friends use facet pumps ... (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) Facet pumps stink ,the only good thing about them is you always know they are working because of the noise (IMG:style_emoticons/default/rolleyes.gif) . Andy did you run @ full pump pressure or run a regulator ,I found my Zeniths ran better @ a lower pressure than pump supplied same with the carbs on my speedster (dcnfva Weber) seemed anything over 3psi was too much for the float needle and seats on both types of carbs. IMO the use of a regulator and gauge is your best friend. I go on but the use of quality (efi rated) fuel hose and correct fuel line clamps is a step ahead from a safety aspect. |
thelogo |
Nov 20 2017, 11:23 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I seem to remember the same pump comes from CB performance also. CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056. http://www.cbperformance.com/product-p/3193.htm Friends don't let friends use facet pumps ... (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/agree.gif) Rotary all the way , my 2.3 needs that steady fuel supply Since i have a slight fuel leak in the engine bay on startup i know its working But honestly a 2.3 running premium fuel with webbbers in a 914 Turns it into more of a race car then a 914 . Stock a 914 is like civilized but with big 4 its obnoxious In a good way . (IMG:style_emoticons/default/bye1.gif) |
Tbrown4x4 |
Nov 21 2017, 04:32 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I really need to do a write-up on this. PO put a Facet on the engine tins and the noise was irritating. I had it running once to warm it up, and it died, leaving the pump to drain the battery. (IMG:style_emoticons/default/sad.gif) (Car would die sometimes as well.)
When I had the tank out to get to the wiper linkage, and decided to install the CB pump. I mounted the pump about where the 75-76 location is, and mounted the filter to the steering rack. For power, I installed one of these: http://www.revolutionelectronics.com/_Medi...in-2_med-2.jpeg Wired into the fuse panel, and attached to the Tach, all the wiring is short and up front. When you key up, the pump runs for 3 seconds to prime, then waits for a tach signal. If you crash your car, the pump stops running so you don't get drenched in fuel. So far, so good. Happy to get rid of that clicking! |
ChrisFoley |
Nov 21 2017, 07:43 AM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
When you key up, the pump runs for 3 seconds to prime, then waits for a tach signal. If you crash your car, the pump stops running so you don't get drenched in fuel. 3 seconds isn't long enough to refill the float bowls after sitting for a week or more, but otherwise its a great safety feature. |
North Coast Jim |
Nov 21 2017, 09:02 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
I seem to remember the same pump comes from CB performance also. CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056. http://www.cbperformance.com/product-p/3193.htm Friends don't let friends use facet pumps ... (IMG:style_emoticons/default/barf.gif) I also run this setup but I purchased mine form Tangerine Racing. Also bought the SS fuel line for Carbs. Used the remaining grommet holes to run the wiring thru the tunnel. Bought a 2 wire multi stranded and flat jacketed wire from West Marine. Mounted the pump/filter combo under the gravel pan. It's tight but it works. Happy to see the pump outside of the car and the pressure line now in SS tube. As insurance I installed on the top of the engine a fuel regulator. I actually use a 2.5lb pressure with 40IDFs on a 2.1L engine. Runs great. |
Mark Henry |
Nov 21 2017, 10:12 AM
For power, I installed one of these: http://www.revolutionelectronics.com/_Medi...in-2_med-2.jpeg Wired into the fuse panel, and attached to the Tach, all the wiring is short and up front. When you key up, the pump runs for 3 seconds to prime, then waits for a tach signal. If you crash your car, the pump stops running so you don't get drenched in fuel. You could also do this by wiring a simple relay to the oil pressure switch, but it has no pre-run. you could get around this with dash mounted momentary switch to prime the pump. $5 plus some wire. Or you could use a fuel pump relay from a VW k-jetronic, uses the tach signal and has a simple 555 timer for pre-run. $27 plus some wire. you might be able to find one in a scrapyard. http://www.busdepot.com/321906059C |
Lo-Fi Version | Time is now: 28th April 2024 - 10:45 PM |
