Fuel Pump for Carbs, Fuel Pump |
simonjb |
Nov 20 2017, 09:25 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I was wondering what fuel pump folks are using and like for a Carb conversion. Engine is a 2.0 upgraded to 2.3 with two Weber 44 IDF carbs.
porschetub |
Nov 20 2017, 01:35 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Low pressure Carter pump mounted on front crossmember,not too loud, fairly priced and runs well.
I seem to remember the same pump comes from CB performance also. |
SirAndy |
Nov 20 2017, 01:55 PM
Resident German Group: Admin Posts: 41,636 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I seem to remember the same pump comes from CB performance also. CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056. http://www.cbperformance.com/product-p/3193.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1511207757.1.jpg) Friends don't let friends use facet pumps ... (IMG:style_emoticons/default/barf.gif) |
porschetub |
Nov 20 2017, 10:21 PM
I seem to remember the same pump comes from CB performance also. CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056. http://www.cbperformance.com/product-p/3193.htm Friends don't let friends use facet pumps ... (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) Facet pumps stink ,the only good thing about them is you always know they are working because of the noise (IMG:style_emoticons/default/rolleyes.gif) . Andy did you run @ full pump pressure or run a regulator ,I found my Zeniths ran better @ a lower pressure than pump supplied same with the carbs on my speedster (dcnfva Weber) seemed anything over 3psi was too much for the float needle and seats on both types of carbs. IMO the use of a regulator and gauge is your best friend. I go on but the use of quality (efi rated) fuel hose and correct fuel line clamps is a step ahead from a safety aspect. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:36 PM |
