Fuel Pump for Carbs, Fuel Pump |
simonjb |
Nov 20 2017, 09:25 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I was wondering what fuel pump folks are using and like for a Carb conversion. Engine is a 2.0 upgraded to 2.3 with two Weber 44 IDF carbs.
Tbrown4x4 |
Nov 21 2017, 04:32 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I really need to do a write-up on this. PO put a Facet on the engine tins and the noise was irritating. I had it running once to warm it up, and it died, leaving the pump to drain the battery. (IMG:style_emoticons/default/sad.gif) (Car would die sometimes as well.)
When I had the tank out to get to the wiper linkage, and decided to install the CB pump. I mounted the pump about where the 75-76 location is, and mounted the filter to the steering rack. For power, I installed one of these: http://www.revolutionelectronics.com/_Medi...in-2_med-2.jpeg Wired into the fuse panel, and attached to the Tach, all the wiring is short and up front. When you key up, the pump runs for 3 seconds to prime, then waits for a tach signal. If you crash your car, the pump stops running so you don't get drenched in fuel. So far, so good. Happy to get rid of that clicking! |
Lo-Fi Version | Time is now: 15th May 2024 - 07:35 PM |
