Show Me Your In Cabin Fire Extinguishers Please!, Stuck! Looking For Some Creative Ideas |
Lucky9146 |
Nov 20 2017, 11:27 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,613 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Ok, I got this cool center pull hand break (not my idea) but I sure like it there.
Now with that said, I have some real estate limitations shall we say. I'd sure appreciate seeing what you guys have done, type, and the size you have selected etc. Thanks (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/white914.jpg) |
Coondog |
Nov 21 2017, 03:42 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
My Purple K is a 5 pound 20 BC
My Halotron is a 2 BC FYI you can still buy Halon extinguishers in the USA it just cannot be manufactured anymore. So if you have a large Halon extinguisher it’s worth $$$$ as it is still allowed to be resold for use in other Halon systems. |
ThreeV8s |
Nov 23 2017, 10:13 AM
Member Group: Members Posts: 116 Joined: 11-March 17 From: West Chester, PA Member No.: 20,915 Region Association: North East States |
My Purple K is a 5 pound 20 BC My Halotron is a 2 BC FYI you can still buy Halon extinguishers in the USA it just cannot be manufactured anymore. So if you have a large Halon extinguisher it’s worth $$$$ as it is still allowed to be resold for use in other Halon systems. Thank you for sharing your front trunk set-up (which makes perfect sense) and information about purple k, which I had not heard of previously. If you had to choose just one extinguisher to keep in the car, would you go with the purple k? Happy Thanksgiving All! |
Coondog |
Nov 23 2017, 10:52 AM
My Purple K is a 5 pound 20 BC My Halotron is a 2 BC FYI you can still buy Halon extinguishers in the USA it just cannot be manufactured anymore. So if you have a large Halon extinguisher it’s worth $$$$ as it is still allowed to be resold for use in other Halon systems. Thank you for sharing your front trunk set-up (which makes perfect sense) and information about purple k, which I had not heard of previously. If you had to choose just one extinguisher to keep in the car, would you go with the purple k? Happy Thanksgiving All! Yes Sir. Purple K puts out serious Fire |
ThreeV8s |
Apr 5 2018, 06:15 PM
My Purple K is a 5 pound 20 BC My Halotron is a 2 BC FYI you can still buy Halon extinguishers in the USA it just cannot be manufactured anymore. So if you have a large Halon extinguisher it’s worth $$$$ as it is still allowed to be resold for use in other Halon systems. Thank you for sharing your front trunk set-up (which makes perfect sense) and information about purple k, which I had not heard of previously. If you had to choose just one extinguisher to keep in the car, would you go with the purple k? Happy Thanksgiving All! Yes Sir. Purple K puts out serious Fire I took @coondog’s advice (finally) and got a 5 lb purple k. It showed up today, but the tamper ring was broken. It was packaged poorly...no packing material, just a box. Should this be sent back? The pressure gauge shows full. One of the first things it says in the inspection section of the instructions is that the tamper seal should be unbroken. |
Coondog |
Apr 6 2018, 08:54 PM
My Purple K is a 5 pound 20 BC My Halotron is a 2 BC FYI you can still buy Halon extinguishers in the USA it just cannot be manufactured anymore. So if you have a large Halon extinguisher it’s worth $$$$ as it is still allowed to be resold for use in other Halon systems. Thank you for sharing your front trunk set-up (which makes perfect sense) and information about purple k, which I had not heard of previously. If you had to choose just one extinguisher to keep in the car, would you go with the purple k? Happy Thanksgiving All! Yes Sir. Purple K puts out serious Fire I took @coondog’s advice (finally) and got a 5 lb purple k. It showed up today, but the tamper ring was broken. It was packaged poorly...no packing material, just a box. Should this be sent back? The pressure gauge shows full. One of the first things it says in the inspection section of the instructions is that the tamper seal should be unbroken. Your OK, but your choice. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:00 PM |
