value of a '70 6cyl 2.0l motor, disassembled |
turbonet |
Nov 21 2017, 03:55 PM
Member Group: Members Posts: 68 Joined: 14-September 16 From: Vancouver Member No.: 20,398 Region Association: Canada |
How much should I expect to pay for a disassembled but otherwise complete 911 2.0l motor with carbs?
Found a motor but I don't know what the value really is. |
mb911 |
Nov 21 2017, 04:47 PM
914 Guru Group: Members Posts: 6,848 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
How much should I expect to pay for a disassembled but otherwise complete 911 2.0l motor with carbs? Found a motor but I don't know what the value really is. Carbs worth 1500-4500 depending on condition and what they are. Engine depending on what needs to be done could be a huge swing.. 1500-2500 as that is value at best of the parts.. If its ready for reassembly and no machine work required maybe more. |
Nov 21 2017, 06:56 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Could be worth a whole lot more to the person who has the 914-6 body that the engine originally came out of.
The 914-6 motor was basically the same as the 1969 911T motor. That was the mildest lowest-powered version of the 911 motor ever put into a series production car by Porsche. It is not in very high demand on its own. But as I said, there may be one person out there who really wants it. --DD |
brant |
Nov 21 2017, 07:32 PM
It’s parts are not in demand either
Crappy heads Crappy crank Not great rods Iron cylinders The case has the right number but it’s not a strong case The 914/6 carbs are worth less than the 911 versions |
gereed75 |
Nov 21 2017, 07:58 PM
Senior Member Group: Members Posts: 1,246 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
i would say that a complete motor without carbs but including the shroud, fan, alternator, distributor is a pretty good deal in the $1500 - $2000 range. Assuming carbs are webers in decent shape, add another $1500.
Assuming you are looking at it as a core for a six swap, if you have to collect all of the ancillary stuff like the shroud alternator fan distributor, it gets pricy, so that stuff has value. i would not want to pay more than the 3000 range complete unless it has other valuable qualities like machined cases, great cams, fresh heads, tensioner upgrades etc etc Still will take 4x that to build a good street motor with an early core because of what Brant says. |
porschetub |
Nov 22 2017, 02:17 AM
Confusing thread,some assumed its a 914/6 motor which I think its not ,OP said "70 911 motor" ,didn't know they built a 2.0l motor in 1970 always thought that year had a 2.2,engine number would help.
My quick research on Wiki indicates this motor will be a 2.2l if its a 1970 motor,my own 1971 2.2 is one of the last before the change to 2.4l in August 71. All that said it is a motor in pieces which drops its value even more,not a powerhouse by any means but could be a good buy @ the right price,I would buy just to have it ANY 911 motor will never get cheaper to buy. |
BK911 |
Nov 22 2017, 03:47 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
911 2.0 could have a sand cast aluminum case and be worth some serious coin.
Or be a 67S engine. A 70 engine could be a 2.2T engine. Or a 2.2 S engine with webers. Need engine type and number. |
Retroracer |
Nov 22 2017, 08:19 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
What he said: need engine number to get a reference point,
Also take care that it is indeed "otherwise complete". It only takes a few missing components on these engines to dramatically increase the net cost when you start reassembly. Ask me how I know ;-) |
GeorgeRud |
Nov 23 2017, 10:38 AM
Have to figure there was a reason it was originally taken apart! If you have to start replacing parts and do some needed machining, you’ll end up with a very expensive ‘cheap’ motor.
Lo-Fi Version | Time is now: 12th May 2024 - 10:20 PM |
