914 pop-up headlight replacement?, Want to run HID projections |
lybones |
May 26 2005, 12:22 PM
Member Group: Members Posts: 159 Joined: 26-April 05 From: Garden Grove, CA Member No.: 3,986 |
Does anyone sell these head light covers for 914s or are they custom made?
I have a set of real HID headlight modules from a Lexus GS 430 that I am going to run in a projection headlight setup. I know they make pop-up replacements for the other cars such as the first generation rx7. Here's a shop that makes really nice shallow projections. http://www.rallylights.com/hella/headlamps.asp Attached thumbnail(s) |
Mueller |
May 26 2005, 12:32 PM
custom.....the 914 is owned by Ed Ducey, username propricer...you might PM him for details
I wonder if the plastic cover changes the lighting pattern???? |
soupbone |
May 26 2005, 05:03 PM
Newbie Group: Members Posts: 43 Joined: 21-November 04 From: Hayward, CA Member No.: 3,157 |
These I think could work in stock buckets but you keep the pop ups. Has high beam and also and DOT legal.
http://www.xesighting.com/products_detail....1&cat=1&prod=94 (IMG:http://www.suvlights.com/Xe7.jpg) |
nebreitling |
May 26 2005, 05:10 PM
Rice-a-Roni!
lapuwali |
May 26 2005, 05:11 PM
There was a topic on this not long ago you should search for. Adding HID lights means upgrading your wiring and adding some extra relays.
lybones |
May 26 2005, 05:23 PM
These are the first I've seen like this, very interesting. The reason I want the plexi buckets is to get rid of the pop-up look. I just think it would look sleek on a jet black gt. |
drew365 |
May 26 2005, 05:40 PM
In California, you can't have covered headlights unless it's a sealed unit. So plexiglass over any headlight is illegal. I finally took the plexiglass covers off my one car after two CHP tickets.
Joe Bob |
May 26 2005, 05:48 PM
Covered headlights are illegal.....hmmmm, what about sealed beams behind glass like my 356 and old bugs?
Mueller |
May 26 2005, 05:51 PM
well, those came from the factory that way.....the plastic people buy at TAP Plastics is not optically clear, the light gets diffused and screws up the beam pattern........... |
Cap'n Krusty |
May 26 2005, 05:53 PM
I was about to point that out. My former boss had to get a letter from Porsche (easy for him, hard for the rest of us) to verify the plexi covers on his 904. Cars originally sold with them are OK. Why give 'em another excuse to stop you? The Cap'n
drew365 |
May 26 2005, 05:55 PM
If the glass covering is sealed it's okay. I guess the concern is condensation building on the inside of the glass and distorting the headlight beam. I had plexiglass over a sealed headlight and it was a no no. Ferrari 275 GTBs came like this in Europe, but technically the covering is illegal here. |
lybones |
May 26 2005, 06:40 PM
So these cars are okay because the plexi cover and projection lights are completely sealed into "one" unit? Attached thumbnail(s) |
lybones |
May 26 2005, 06:43 PM
Here's an Idea. Buying a solid fiberglass hood with no head light pockets and doing something like this. ( just an idea).
TonyAKAVW |
May 26 2005, 06:44 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
There's also a minimum height requirement for headlights in most states. In California I believe it is 22 inches or something like that. I read it once in the vehicle code. I measured my 914 and the top of the headlights meet that requirement. I'm not so sure of having headlights integral to the hood would meet that minimum height.
-Tony |
drew365 |
May 26 2005, 06:46 PM
That's the way I understand it. |
FriarJohn |
May 26 2005, 11:37 PM
Non-914-Owner Group: Members Posts: 134 Joined: 29-January 03 Member No.: 211 Region Association: None |
That 914 looks similar to mine back when I first bought it, with the cut-outs in the bumper, but without the glass on top:
(IMG:http://friar.johnbedard.com/albums/album07/original_front.jpg) (IMG:http://friar.johnbedard.com/albums/album07/original_leftfront.jpg) The housings were custom made by a PO. The headlights are 5x7 GM style cheapie halogens. |
airsix |
May 26 2005, 11:54 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
If the HIDs are small just mount them in the top portion of the headlight bucket. Then change the geometry of the headlight pop-up linkage to just open them enough to expose the HID bulb/reflector. I think that would be cool. Popups that only popup 3 inches or so.
-Ben M. |
lybones |
May 27 2005, 12:39 AM
Thanks for all the input everybody. Very interesting ideas. My HID modules are very small, but will need a projector housing of some sort. Here's a pic. |
lybones |
May 27 2005, 12:40 AM
OOPS, here's the pic
914efi |
May 27 2005, 05:31 AM
Member Group: Members Posts: 140 Joined: 14-June 04 From: Westport,MA Member No.: 2,204 Region Association: None |
Sylvania has a product called the X1010 (about to be discontinued) that is an aux HID 'low beam' driving light. You could put them where the fogs go. They have a really cool remote so you don't run wires into the car. ~$350.00
Lo-Fi Version | Time is now: 8th May 2024 - 03:28 PM |
