Sputter/cut out at high RPM, is it the distributor? |
Groosh |
Nov 23 2017, 12:03 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Happy Thanksgiving!
I'm getting a cut out at higher RPMs but it pulls well. I currently run Hot Spark on the original dizzy and the fuel pressure is solid. I have oiled the distributor with some results but before I go buy a new one, I wondered if there is something else I might try. |
mgphoto |
Nov 23 2017, 01:40 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Oil could be a problem.
Best to use Bosch high temp dizzy grease. FI points are low voltage, they don't burn impurities off, causes the engine to stutter. The Bosch stuff stays put when hot. |
Groosh |
Nov 23 2017, 01:44 PM
Oil could be a problem. Best to use Bosch high temp dizzy grease. FI points are low voltage, they don't burn impurities off, causes the engine to stutter. The Bosch stuff stays put when hot. I'll clean it up but would this still be a problem with the Hot Spark electronic ignition? |
Lo-Fi Version | Time is now: 13th May 2024 - 04:10 PM |
