Cayenne motor swap, Let’s hear it all! |
r_towle |
Nov 23 2017, 06:15 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Has anyone managed to stuff a cayenne motor into a 914?
What transmission? What about fuel and ignition? |
Andyrew |
Nov 24 2017, 09:41 AM
The 6 is just a VR6. Mueller was going to do it on his old car and I think it would work. Just a brick of an engine (heavy) for the power outlet. However if you wanted to put a monster turbo on it and go for 700 hp thats not a bad choice.
Mueller |
Nov 24 2017, 11:45 AM
The 6 is just a VR6. Mueller was going to do it on his old car and I think it would work. Just a brick of an engine (heavy) for the power outlet. However if you wanted to put a monster turbo on it and go for 700 hp thats not a bad choice. The better Porsche V6 would be from the Macan, it is a true 90° V6, basically 2 cylinders removed from the Cayenne V8. BradR thinks many wreckers would take as low as $1500 for one since there is no demand. George, the Macan V6 comes from the factory twin turbo'd! |
Andyrew |
Nov 24 2017, 06:13 PM
The 6 is just a VR6. Mueller was going to do it on his old car and I think it would work. Just a brick of an engine (heavy) for the power outlet. However if you wanted to put a monster turbo on it and go for 700 hp thats not a bad choice. The better Porsche V6 would be from the Macan, it is a true 90° V6, basically 2 cylinders removed from the Cayenne V8. BradR thinks many wreckers would take as low as $1500 for one since there is no demand. George, the Macan V6 comes from the factory twin turbo'd! Hmm, Did he comment on the bolt pattern? I would be curious to see what it would take to bolt it to a manual trani. Probably custom flywheel required. Are they available in a manual? I mean a PDK would be a blast (IMG:style_emoticons/default/smile.gif) As with most modern engines, electronics would probably be the biggest issue.... |
Lo-Fi Version | Time is now: 19th May 2024 - 06:40 AM |
