Acceptable voltage discrepancy, Voltage at dash vs. voltage at battery |
98101 |
Nov 24 2017, 06:26 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I started my car after sitting a few days and noticed the dash voltage meter went up over 15V. In Tech Tips 700 I read that overvoltage could lead to battery acid spills, so I quickly shut it off.
Prior to that, I'd noticed the dash gauge reads lower than I'd like when all the lights are on. I checked the voltage at the battery under different circumstances and they weren't so extreme in either direction. So now I'm wondering what the acceptable differences would be before you'd start to expect a poor (ground?) connection somewhere? https://www.youtube.com/watch?v=S6BcQC-cjXo |
Mike Bellis |
Nov 24 2017, 06:35 PM
Most alternators do not charge much at all at idle. That means you are running off battery. When you rev above 1200 rpm or so it should start charging and it looks like it does. Your amp gauge indicates the negative discharge at idle. As long as the amp reading shows positive charge after diving a few miles, you have nothing to worry about.
Lo-Fi Version | Time is now: 25th May 2024 - 12:40 AM |
