stranded in Cambria CA, overrev on Santa Rosa Creek Road |
davesprinkle |
Nov 25 2017, 11:52 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Driving Santa Rosa Creek Road today. I banged a 3-2 downshift. Couple of pops in the exhaust, then no torque. I coast to a stop. Engine cranks fast but doesn't light.
I put a finger on the air flap and hear the fuel pump run. Good. Voltage to the coil? 10.8V. (Low, but I've been cranking on this damn thing for a bit. So, OK.) I pull the distribulator cap and look at the points. OK. I'm out of easy options, so I start walking. Seven miles back to town. No cell service. I'm thinking I bent some valves on an over-rev. Here's a pic: Attached image(s) |
davesprinkle |
Nov 26 2017, 12:01 AM
I walk back to Cambria. It's dark. Can't extract the car tonight.
I go to the Creekside Inn. The guy behind the counter says they've got a room. I say I'll take it. He offers me some weed. You know, for medicinal purposes. I say thanks, but I'm not sick. Got any mescal? I wait 30 minutes for the one guy in town who drives a taxi. He doesn't show. Hotel counter guy says for 20 bux I'll drive you. So when we're getting in his Corolla, I see he's got a tracker beacon strapped to his ankle. Great. We drive back to the 914. It's dark. On the way there, we hit an owl. The 914 is still where I left it. It still won't start. I get my bag. Now I'm back in the room. Thankfully, they provide wine glasses here. Finest hotel I've ever been in. Attached image(s) |
ConeDodger |
Nov 26 2017, 12:09 AM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Well, damn. But there are worse places to stranded. Elliot isn’t too far off...
Krieger |
Nov 26 2017, 12:10 AM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Damn! Maybe your coil took a crap. Check for spark. Hard to crank and look for sparking plug wire alone. Don't drink too much vino tonight. You have a busy day ahead. Good luck bro!
EdwardBlume |
Nov 26 2017, 07:15 AM
Was Mr Anklebracelet's name Norman? Was he complaining about his Mom?
Sorry for your misfortune, but glad to see things are getting better. There a P shop in SLO if you can't get it going... |
McMark |
Nov 26 2017, 07:20 AM
'73-914kid |
Nov 26 2017, 08:06 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
If I remember correctly, there's a NAPA in Cambria, or at least there used to be, as well as a number of hot rod shops all in a small industrial park on the south part of the town.
Does the car sound the same as it usually does when it cranks? If you smacked/bent valves, you would hear one or more cylinders lacking compression when cranking, as the motor speeds up on the compression stroke of the bad cylinder. I would check for spark. I know it happened on a rough downshift, but a couple of pops, then nothing, sounds like a bad ignition coil. I've had a couple of coils fail and cough a similar death.. Man, if only this happened to you a week later.. Ill be up there next weekend.. |
jim_hoyland |
Nov 26 2017, 08:16 AM
Get that VIN ? Group: Members Posts: 9,286 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Oh My ! Been on Santa Rosa Creek Road many times, what a terrible place to break down. Been to Creekside inn too, that guy is great. There is a Napa just off Burton Road and IIRC they know a VW mechanic.
Good luck Dave (IMG:style_emoticons/default/smile.gif) |
drifter914 |
Nov 26 2017, 09:51 AM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Also... check to see if coil is loose in bracket. If it rotates around, can sometimes ground itself on engine tin. Same result !
Hope it's something simple. |
timothy_nd28 |
Nov 26 2017, 10:26 AM
Sounds like your air flow meter got blown during that back fire. This happened to me while on a road trip.
A very temporary fix would be removing the cover, and positioning the airflow meter flap in a neutral position. A neutral position is where the car runs like shit at idle and runs like shit at 50mph, nonetheless it's running. I drove my car 30 miles in this condition, enough to get me home. This will only work if the AFM flap is sticking. |
davesprinkle |
Nov 26 2017, 10:34 AM
Does the car sound the same as it usually does when it cranks? If you smacked/bent valves, you would hear one or more cylinders lacking compression when cranking, as the motor speeds up on the compression stroke of the bad cylinder. The car definitely sounds different during cranking. Spins very fast. I'm thinking I tapped valves in all four. |
RickS |
Nov 26 2017, 10:38 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Breaking down is never easy no matter how beautiful the countryside. At least you could drown your sorrows with a good cab after getting your exercise in. Not many would have such a good attitude (relatively speaking) about such an event.
Wish I could give you an easy solution but what you described sounded expensive as missed shifts usually are. Hope you can get that gorgeous car back on the backroads soon. Great writing style btw. |
davesprinkle |
Sounds like your air flow meter got blown during that back fire. This happened to me while on a road trip. A very temporary fix would be removing the cover, and positioning the airflow meter flap in a neutral position. A neutral position is where the car runs like shit at idle and runs like shit at 50mph, nonetheless it's running. I drove my car 30 miles in this condition, enough to get me home. This will only work if the AFM flap is sticking. Yeah. I did check for AFM movement when I was running the fuel pump. Moves freely. |
Larmo63 |
Nov 26 2017, 10:40 AM
Sorry about your predicament. Your car LOOKS great, even in a tenuous situation. (IMG:style_emoticons/default/blink.gif)
GregAmy |
Nov 26 2017, 10:58 AM
Advanced Member Group: Members Posts: 2,291 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Does the car sound the same as it usually does when it cranks? If you smacked/bent valves, you would hear one or more cylinders lacking compression when cranking, as the motor speeds up on the compression stroke of the bad cylinder. The car definitely sounds different during cranking. Spins very fast. I'm thinking I tapped valves in all four. That's the same symptom when I grabbed 3rd instead of 5th on the front straight at the LRP Historics. Spins fast, no compression. All four exhaust valves bent. |
914-300Hemi |
Nov 26 2017, 11:26 AM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
It is never fun to break down while taking a fun drive. Good luck and hope it is an easy fix like the coil.
Keep us posted. |
Elliot Cannon |
Nov 26 2017, 12:08 PM
I'm about 45 miles away in Paso Robles. I have a tow bar and hitch that I can unbolt from my car and bolt on to your suspension (if you don't have the same tow bar connection on yours) and I can tow you to a good Porsche shop that has done work for me in the past in San Luis Obispo. Here's the address if you want to use AAA or some other towing service. You can call me at 805 975 6616
Guys Porsche 1144 Higera st San Luis Obispo 805 545 9323 |
ValcoOscar |
Nov 26 2017, 12:25 PM
Garage Life Group: Members Posts: 2,384 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I'm about 45 miles away in Paso Robles. I have a tow bar and hitch that I can unbolt from my car and bolt on to your suspension (if you don't have the same tow bar connection on yours) and I can tow you to a good Porsche shop that has done work for me in the past in San Luis Obispo. Here's the address if you want to use AAA or some other towing service. You can call me at 805 975 6616 Guys Porsche 1144 Higera st San Luis Obispo 805 545 9323 Elliot to the rescue....D'man of the day Oscar |
davesprinkle |
Nov 26 2017, 01:51 PM
Sorry about your predicament. Your car LOOKS great, even in a tenuous situation. (IMG:style_emoticons/default/blink.gif) Thanks for the kind words. The car was running well, at least until the driver ruined it all. That road suits a 100hp car. It was fun. |
davesprinkle |
Nov 26 2017, 01:54 PM
I'm about 45 miles away in Paso Robles. I have a tow bar and hitch that I can unbolt from my car and bolt on to your suspension (if you don't have the same tow bar connection on yours) and I can tow you to a good Porsche shop that has done work for me in the past in San Luis Obispo. Here's the address if you want to use AAA or some other towing service. You can call me at 805 975 6616 Guys Porsche 1144 Higera st San Luis Obispo 805 545 9323 Elliott, thanks! What a generous offer. Funny you mention Guys Porsche. I just dropped the car there and spoke with Guy himself. He was in the shop working the weekend. They'll do a compression check and diagnosis tomorrow. Meanwhile, I've got a rental Veloster, the ugliest car on the planet. |
Lo-Fi Version | Time is now: 13th May 2024 - 02:37 AM |
