Take a road trip in a car that's been sitting? |
McLovin |
Nov 26 2017, 11:12 PM
Member Group: Members Posts: 102 Joined: 31-August 16 From: Tallahassee, FL Member No.: 20,360 Region Association: South East States |
Hey guys,
My 914 has been sitting for over a year since I got it. I bought a "turn key" car, but it still needs brakes and an oil leak fixed. Otherwise, it's in pretty good shape. I know my fuel lines are good. But the car has been sitting. And before I bought it, I know it sat a couple years getting cosmetics. So essentially, when I get my car on the road, it will have decent rubber lines and tires, but it will have sat for a few years. Assuming I change the oil , make sure my battery is up to par and adjust the valves, how worried should I be about taking it out of town on a 200 mile trip? My town is about 200 miles in three directions from interesting big cities, and I know I'll want to use it to go to events out of town. Are these gems reliable? I have a company truck, but I can use for personal stuff but I can't take it out of town. Thanks! |
Mike Bellis |
Nov 26 2017, 11:24 PM
Pull the spark plugs and put a few drops of oil in the cylinders. Then crank it to get the oil flowing. Only then should you try to start it.
iankarr |
Nov 26 2017, 11:27 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I'd definitely make sure the brakes are 100% and include fresh gas on the prep list. Unless you treated what was in there with sta-bil. Old gas is no bueno and you may need to drain what's in there.
Try some hour long trips on the roads around your neighborhood first, and if all goes well, then venture further. Def make sure you have a AAA platinum membership, which includes long-range towing if needed. Yes, these cars can be reliable, but they are 40+ years old and there's always a chance something will give out while you're driving. Be safe and good luck! |
McLovin |
Nov 26 2017, 11:28 PM
Pull the spark plugs and put a few drops of oil in the cylinders. Then crank it to get the oil flowing. Only then should you try to start it. Thanks. Forgot to say that I've been starting it about once a month and keeping it low on gas on-purpose. It's not really dormant. Just not driven. |
mgp4591 |
Nov 27 2017, 12:05 AM
914 Guru Group: Members Posts: 5,370 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Pull the spark plugs and put a few drops of oil in the cylinders. Then crank it to get the oil flowing. Only then should you try to start it. Thanks. Forgot to say that I've been starting it about once a month and keeping it low on gas on-purpose. It's not really dormant. Just not driven. Keeping it low on gas in the tank isn't a good idea. Even with small temp changes between day and night, you can get condensation in the tank and water in your gas is not what you want. Fill it, run it a bit and refill to the top. I'd run Sta-bil in it all the time to help keep the gas fresher but avoiding the water to begin with is the way to go. |
McLovin |
Nov 27 2017, 12:21 AM
Pull the spark plugs and put a few drops of oil in the cylinders. Then crank it to get the oil flowing. Only then should you try to start it. Thanks. Forgot to say that I've been starting it about once a month and keeping it low on gas on-purpose. It's not really dormant. Just not driven. Keeping it low on gas in the tank isn't a good idea. Even with small temp changes between day and night, you can get condensation in the tank and water in your gas is not what you want. Fill it, run it a bit and refill to the top. I'd run Sta-bil in it all the time to help keep the gas fresher but avoiding the water to begin with is the way to go. Good info. I was going to seek out some marine gas this week, but perhaps stabil makes more sense. I am trying to run it enough to keep the lines clear. |
914Sixer |
Nov 27 2017, 06:42 AM
914 Guru Group: Members Posts: 8,879 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Take it out for a couple of 30 minute runs. Go though and learn what quirks the car may have.
Coondog |
Nov 27 2017, 07:16 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Bring a Fire Extinguisher.........
Front yard mechanic |
Nov 27 2017, 07:26 AM
Senior Member Group: Members Posts: 1,162 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I suggest you take a long trip in a a car sitting , if you stand up you will get bugs in your teeth (IMG:style_emoticons/default/lol-2.gif)
mgphoto |
Nov 27 2017, 12:40 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Do all of the major service items in the owners manual, check the brakes thoroughly.
Bring that fire extinguisher, start with short stints, work up to longer distances. Than drive the snot out of it, the car will love it and so will you! 380K on mine, longest trip cross country 1989, burnt up a wheel bearing in Texas, fixed it in the motel parking lot, still have the Blackhawk hammer I bought with the bearing. |
Nov 27 2017, 12:53 PM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Bring a Fire Extinguisher......... Unfortunately, this is good advice ... (IMG:style_emoticons/default/sad.gif) |
Andyrew |
Nov 27 2017, 04:14 PM
Watch Roadkill on youtube and you'll get some ideas on what you'll run up against (IMG:style_emoticons/default/smile.gif)
burton73 |
Nov 27 2017, 04:39 PM
burton73 Group: Members Posts: 3,517 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I'd definitely make sure the brakes are 100% and include fresh gas on the prep list. Unless you treated what was in there with sta-bil. Old gas is no bueno and you may need to drain what's in there. Try some hour long trips on the roads around your neighborhood first, and if all goes well, then venture further. Def make sure you have a AAA platinum membership, which includes long-range towing if needed. Yes, these cars can be reliable, but they are 40+ years old and there's always a chance something will give out while you're driving. Be safe and good luck! When you sine up with AAA Platinum membership it takes 15 to go through. If you had a tow they make you wait 90 days till you sine up and then the 15 days. I had to tow my car to Lemons house and pay $230 and then wait. Bob B |
Racer |
Nov 27 2017, 04:44 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Its a 40+ year old car. Plan for the worst (needing a tow) and hope for the best! As mentioned, sort the brakes and get some stabil in there. Maybe doe a regular tune up (points, plugs, condesor if you don't know how old they are) in addition to a few local trial runs to build your confidence in the car.
If you have ethanol fuels, the issue isn't so much the use, its the sitting.. it attracts water and is corrosive when it sits in carbs, fuel injectors etc for long enough periods. Marine fuel would be better if available. Carry an FE, some spare fuses and depending how handy you are, the appropriate small tools or manuals. |
forrestkhaag |
Nov 27 2017, 08:16 PM
Plan for the worst?!! Plan for the best!
Here's the thing all of the posts above are talking about. They know. Some have experienced most of all of it. I know I have. Coondog is more right than all of us. A good Fireman knows. Bring a good halon fire extinguisher. Always. Charged correctly. My lovely 356 SC Solex carbed cranking beast of the 70's burst into flames and I had no way to put it out / he gone............. Pay your insurance. fully Then pack a really cool picnic basket with two crystal stems / not plastic. Never Plastic...... A select bottle of fine sparkling...... water......... er....... Prepare a condiment tray (the five compartment type you see at the bar) and, knowing that the under-area of the tray holds ice and water, fill it / with olives of two colors, cheese of two colors, and a selection of your local smoked fish and well spiced and cooked shrimp. Add Carrs Water Crackers and ten gallons of gas and hit the gas pedal. remember the picnic blanket. You might get lucky..... and not need it for a repair............ Hah! The rest of your 914 story - is a story, and if it goes as planned, we would only hear the trimmings of your drive and picnic. But do it. Otherwise, ...... (IMG:style_emoticons/default/beerchug.gif) |
Unobtanium-inc |
Nov 27 2017, 11:03 PM
Advanced Member Group: Members Posts: 2,208 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Before you take it on a long trip, take it on 2-3 short ones, like an hour or two. And have a AAA+ card, along with a fire extinguisher. I made the mistake of taking my car to PA and back shortly after pulling it out of storage, made it home on three cylinders, it wasn't fun.
DRPHIL914 |
Nov 28 2017, 10:36 AM
I have driven my car on a half dozen trips of 5 hours or more and 2 of 900 miles!!! - that was taking it from SC to Conn to Tangerine racing for work( I only stopped 2x for gas and stretch, drove thru night because it was cooler and less traffic) , then back home afew months later. But before I did that I had replaced all of my suspension, brakes, bushings bearings etc. so all the safety issues were taken care of, and fuel lines etc all replaced. - SO the state of your car matters. my car has 150k miles on it now and I didn't hesitate to take it to Okteenerfest 5 hours away. but take the test drives etc as suggested, also have an extra petronix unit, points, coil, spare tire, jack, etc triple a AAA , I have Haggarty with roadside assistance and long distance towing , - flares , and take the car and have a great trip. 200 miles I would not hesitate at all , but with all the updating ive done the car is like new mechannicall except for the motor and it has good compression numbers , - sure things can happen but I thing I could have just as great a chance and having an issue with my 2000 BMW 528i that has 253k miles on it! - but again, my car is well maintained, so I would not hesitate with it either. have a great trip!, Phil |
McLovin |
Nov 28 2017, 12:12 PM
(IMG:style_emoticons/default/agree.gif) I have driven my car on a half dozen trips of 5 hours or more and 2 of 900 miles!!! - that was taking it from SC to Conn to Tangerine racing for work( I only stopped 2x for gas and stretch, drove thru night because it was cooler and less traffic) , then back home afew months later. But before I did that I had replaced all of my suspension, brakes, bushings bearings etc. so all the safety issues were taken care of, and fuel lines etc all replaced. - SO the state of your car matters. my car has 150k miles on it now and I didn't hesitate to take it to Okteenerfest 5 hours away. but take the test drives etc as suggested, also have an extra petronix unit, points, coil, spare tire, jack, etc triple a AAA , I have Haggarty with roadside assistance and long distance towing , - flares , and take the car and have a great trip. 200 miles I would not hesitate at all , but with all the updating ive done the car is like new mechannicall except for the motor and it has good compression numbers , - sure things can happen but I thing I could have just as great a chance and having an issue with my 2000 BMW 528i that has 253k miles on it! - but again, my car is well maintained, so I would not hesitate with it either. have a great trip!, Phil Thanks, that's good info. As a side note, you stopped every 200 miles or so? How was that? I mean, I can't decide if the car would be terribly uncomfortable because the seats are thin, or reasonably comfortable because you're practically lying down. Are long trips grueling, or just like other cars? |
motofoto |
Nov 28 2017, 03:17 PM
Newbie Group: Members Posts: 18 Joined: 11-June 17 From: Newberg, OR Member No.: 21,169 Region Association: Pacific Northwest |
I did a Calgary to Portland trip when I bought my last 914, and I was really shocked at how comfortable I was. The car fits me just right, and the seat was more supportive than I was expecting. Great for a passenger too, so roomy over there! |
Chris914n6 |
Nov 28 2017, 03:31 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Thanks, that's good info. As a side note, you stopped every 200 miles or so? How was that? I mean, I can't decide if the car would be terribly uncomfortable because the seats are thin, or reasonably comfortable because you're practically lying down. Are long trips grueling, or just like other cars? That depends on your butt. I can and have done 10-12 hours straight in my Nissan Pathfinder and before that in the Hardbody, the seating position works that well for me. On the other hand I can't do an hour in Moms Toyota Highlander before it pinches a nerve making my left leg numb. I find the 914 seats with a 1.5" bottom pad (autox style) fine for road trips, the girl doesn't. I didn't find a stock pad all that comfortable. You need to do some shake down runs - drive it to work everyday kind of stuff. |
Lo-Fi Version | Time is now: 13th May 2024 - 04:21 AM |
