Slightly off topic, decided to finally get it back on the road, 911 clutch slave cylinder |
rktmn247 |
Nov 29 2017, 01:41 AM
Irish Green with GT envy! Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None |
Well, I've been procrastinating for longer than I'm willing to admit. Have to get the 911 back on the road to make space to start on the 914. Sooo... I thought it was just the slave cylinder. No had to drop the engine and trans, and it turns out I broke the release bearing and the arm. Parts on the way, then valve adjust while the engine is out, and then put everything back in. Been so long since I've driven it I'm super stoked to get it back on the road!
Attached thumbnail(s) |
rktmn247 |
Nov 29 2017, 02:11 AM
The broken parts.
barefoot |
Nov 29 2017, 05:23 AM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
While you're in there, pull that cat converter off and check to see if it's been melted internally, would make a big flow resistance if so. (mine was gutted when I got it, but I've seen bad examples)
mb911 |
Nov 29 2017, 06:58 AM
914 Guru Group: Members Posts: 6,842 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Kent I would suspect your progress is slowed due to the diaper boxes next to the 911? (IMG:style_emoticons/default/biggrin.gif)
Thats how it is at my house. |
DRPHIL914 |
Nov 29 2017, 08:05 AM
just recently began having an issue that I think may be the slave cylinder on my '97 boxster clutch - pedal not wanting to pop all way back up if cold or sitting a long time, - what were the symptoms of your issue before you pulled the motor to check on the other parts? I'm hoping a new slave cylinder is the solution, as I really don't want to have to pull my transmission , since the 914 already is at body shop and the motor and transimission for that are on the garage floor taking up space waiting my attention!, anyway your experience here may help me figure mine out.
rktmn247 |
Nov 29 2017, 10:18 AM
Kent I would suspect your progress is slowed due to the diaper boxes next to the 911? (IMG:style_emoticons/default/biggrin.gif) Thats how it is at my house. Kids and grandchildren have contributed some, but it's mostly my fault. |
rktmn247 |
Nov 29 2017, 10:27 AM
just recently began having an issue that I think may be the slave cylinder on my '97 boxster clutch - pedal not wanting to pop all way back up if cold or sitting a long time, - what were the symptoms of your issue before you pulled the motor to check on the other parts? I'm hoping a new slave cylinder is the solution, as I really don't want to have to pull my transmission , since the 914 already is at body shop and the motor and transimission for that are on the garage floor taking up space waiting my attention!, anyway your experience here may help me figure mine out. I was having trouble going into gear and was pressing harder on the pedal when I pushed it past the stop. The pedal stuck and when I pulled it back out he rod came out of the master cyl. Replaced the master and when doing the slave cyl. we found that the release arm was not lined up right. |
rktmn247 |
Nov 30 2017, 10:08 AM
Clutch is repaired! Drove it around the neighborhood a little. Now I have a lot of cleaning to do, bleed brakes, fix tail light, and....... No pics during the reassembly, to busy.
rktmn247 |
Nov 30 2017, 10:12 AM
Oh, and now I found cracks in the fan housing so I need to replace that.
Nov 30 2017, 04:28 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Yeah, we just found cracks in the fan ring on Da Boss' SC... They're NLA. (IMG:style_emoticons/default/sad.gif)
--DD |
porschetub |
Nov 30 2017, 04:48 PM
Just leave it unless the fan is touching,folks tend to overtighten the mounting strap and that doesn't help.
worn |
Nov 30 2017, 06:42 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Yeah, we just found cracks in the fan ring on Da Boss' SC... They're NLA. (IMG:style_emoticons/default/sad.gif) --DD What about the alu repros? Still available? Same with my SC. |
worn |
Sorry double post
porschetub |
Nov 30 2017, 07:47 PM
IronHillRestorations |
Nov 30 2017, 08:03 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Not sure which ones they are reproducing, but Vertex is got some
Lo-Fi Version | Time is now: 12th May 2024 - 01:59 AM |
