Battry, Jump start |
cpavlenko |
Nov 29 2017, 05:18 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
What's the correct way to jump 914
76-914 |
Nov 29 2017, 05:22 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
pos to pos then neg to neg
Nov 29 2017, 05:23 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
One of the easiest cars to push start
Nov 29 2017, 05:24 PM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
cpavlenko |
Nov 29 2017, 05:33 PM
Yes, I know the correct way with pos/neg hook up, and yes it very easy to push start, but I have read some where that if you jump start from another vehicle you could hurt the alternator.
Olympic 914 |
Nov 29 2017, 07:24 PM
Group: Members Posts: 1,663 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
You don't have the charging vehicle running when you try to start the teener.
You can hook up the charging vehicle and just let it run for a while to charge up the battery in the teener ( or whatever you are charging) But be sure shut off the charging vehicle before trying start the teener. use this method to jump start motorcycles also. the 100+ amp charging system of newer vehicles will burn out the regulator on our older cars |
Tom_T |
Nov 30 2017, 01:32 PM
Just get one of those Lithium Battery charging units & keep it charged up in the car. They're smaller & lighter than a set of good cables anyway, & can start several cars off of a full charge.
(IMG:style_emoticons/default/beerchug.gif) Tom /////// |
stugray |
Nov 30 2017, 02:21 PM
whenever I jump a car I leave the charging car running, BUT I stand right at the battery and disconnect the second the dead car comes to life.
It is bad for the two voltage regulators to fight each other, but they can all take it briefly. |
cpavlenko |
Dec 1 2017, 09:47 AM
Thanks for all the info, much appreciated. I do have a portable jump start system I use for my Telescope. Stanley 300 amp instant starting power, jump-start system 600 amp peak battery amps, with USB, cables, and 12 volt outlet. Worked fine to start the teener...
Lo-Fi Version | Time is now: 11th May 2024 - 07:26 AM |
