cpavlenko
Nov 29 2017, 05:18 PM
What's the correct way to jump 914
76-914
Nov 29 2017, 05:22 PM
pos to pos then neg to neg
Nov 29 2017, 05:23 PM
One of the easiest cars to push start
Nov 29 2017, 05:24 PM
QUOTE(76-914 @ Nov 29 2017, 03:22 PM)
cpavlenko
Nov 29 2017, 05:33 PM
Yes, I know the correct way with pos/neg hook up, and yes it very easy to push start, but I have read some where that if you jump start from another vehicle you could hurt the alternator.
Olympic 914
Nov 29 2017, 07:24 PM
You don't have the charging vehicle running when you try to start the teener.
You can hook up the charging vehicle and just let it run for a while to charge up the battery in the teener ( or whatever you are charging) But be sure shut off the charging vehicle before trying start the teener.
use this method to jump start motorcycles also. the 100+ amp charging system of newer vehicles will burn out the regulator on our older cars
Tom_T
Nov 30 2017, 01:32 PM
Just get one of those Lithium Battery charging units & keep it charged up in the car. They're smaller & lighter than a set of good cables anyway, & can start several cars off of a full charge.
Tom
stugray
Nov 30 2017, 02:21 PM
whenever I jump a car I leave the charging car running, BUT I stand right at the battery and disconnect the second the dead car comes to life.
It is bad for the two voltage regulators to fight each other, but they can all take it briefly.
cpavlenko
Dec 1 2017, 09:47 AM
Thanks for all the info, much appreciated. I do have a portable jump start system I use for my Telescope. Stanley 300 amp instant starting power, jump-start system 600 amp peak battery amps, with USB, cables, and 12 volt outlet. Worked fine to start the teener...
