Another GB from 914rubber.com - Bet you cant break these. SOLID STAINLESS, Rear trailing arm Bushings and support rod $120 for the set |
Mikey914 |
Nov 30 2017, 10:59 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Having the experience of rebuilding Matt's barn find, we noticed that there was rust around the edges of the tubes that went through the control arms. After cleaning these up we noticed that these were constructed from hollow tubes that had a plate with a bolt end welded on. The welds had not been cleaned up well and rust had pitted the them and allowed for water penetration actually allowing the inside of the tube to rust.
We made replacement simple. Machining the new tubes from stainless steel they will never be able to rust and fail. Once we had the center shafts ready we made the bushings from rubber just like factory. These proved difficult to install, so we switched this up to poly-graphite and they we much easier to install. So our "kit" comprises 2 - solid stainless steel pivot shafts, and 4 poly-graphite bushings. I have 2 other GBs I'm about to post - The front strut top rubber replacement The A arm bushings - with or without special tools to install Attached thumbnail(s) |
aggiezig |
May 4 2018, 10:46 AM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
I'm curious if anyone has feedback after installing this kit?
My only hesitation is with the poly-graphite bushings. There seems to be a lot of (mis)information about there about bushings and a lot of folks use the term "poly" interchangeably and I know there's a difference between polyurethane bushings and polygraphite bushings. So, for anyone who has installed these parts: 1) How hard / easy is the install? Any bushing honing required? Any JB Weld required? 2) How is the ride compared to rubber bushings? 3) Is there any squeaking or binding? Feedback greatly appreciated! |
Lo-Fi Version | Time is now: 26th May 2024 - 11:47 AM |
