Another GB from 914rubber.com - Bet you cant break these. SOLID STAINLESS, Rear trailing arm Bushings and support rod $120 for the set |
tyfighter123 |
Dec 23 2017, 08:29 PM
Newbie Group: Members Posts: 41 Joined: 22-September 16 From: Grand Junction Member No.: 20,422 Region Association: Rocky Mountains |
Ill take a set!
maf914 |
Dec 24 2017, 04:26 PM
Is there still time to join the group buy? If so, I will take a set. Thanks for offering these.
Mblizzard |
Dec 24 2017, 09:12 PM
pete000 |
Jan 14 2018, 10:43 PM
I started looking at these and found a couple of observations I wanted to pass along.
As for quality they are top notch. Nicely machined. The bushings are very well made. (IMG:style_emoticons/default/first.gif) As for weight they are very heavy ! 6 pounds 15.5 ounces per pair vs the stock hollow axles that weigh in at 2 pounds 9.5 ounces per pair. So these are more than double the weight over stock. I understand they are indestructible, but I have never heard of a stock part ever failing so not sure if the weight penalty is worth it in this case. Also the ends are not serrated and a I am not sure if this is an issue but the factory put the serrations in for a reason I suspect. It would be cool if you could just order the Poly bushings separate skipping the axles for the people wanting to just run the stock pivot axles. The "E" brand does not sell their rubber bushings separate either. The bushings slip right in the trailing arms very easy and installation is very easy compared to the horror stories you hear from the other manufactures. I am interested in hearing others opinions on the ride quality and how quiet they are. (IMG:style_emoticons/default/popcorn[1].gif) Thanks ! Attached thumbnail(s) |
Jan 15 2018, 05:37 AM
914-6 GT in waiting Group: Members Posts: 19,247 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Your stock axles look new. All the ones I've ever seen on the east coast are rusty and corroded.
ChrisFoley |
Jan 15 2018, 10:23 AM
I am Tangerine Racing Group: Members Posts: 7,919 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The "E" brand does not sell their rubber bushings separate either. Their bushings are a different id. Therefore, only their shafts fit their bushings. I've been selling new solid pivot shafts for years - made of a higher strength material and the same diameter as oem. Mine don't have the toothed ends either but I can add them if necessary. |
aggiezig |
May 4 2018, 10:46 AM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
I'm curious if anyone has feedback after installing this kit?
My only hesitation is with the poly-graphite bushings. There seems to be a lot of (mis)information about there about bushings and a lot of folks use the term "poly" interchangeably and I know there's a difference between polyurethane bushings and polygraphite bushings. So, for anyone who has installed these parts: 1) How hard / easy is the install? Any bushing honing required? Any JB Weld required? 2) How is the ride compared to rubber bushings? 3) Is there any squeaking or binding? Feedback greatly appreciated! |
May 4 2018, 10:49 AM
I'm curious if anyone has feedback after installing this kit? My only hesitation is with the poly-graphite bushings. There seems to be a lot of (mis)information about there about bushings and a lot of folks use the term "poly" interchangeably and I know there's a difference between polyurethane bushings and polygraphite bushings. So, for anyone who has installed these parts: 1) How hard / easy is the install? Any bushing honing required? Any JB Weld required? 2) How is the ride compared to rubber bushings? 3) Is there any squeaking or binding? Feedback greatly appreciated! Mine installed easily. No JB weld is used on this kit. I have not driven on them yet. |
Mikey914 |
The rubber man Group: Members Posts: 12,648 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Mine are polygraphite, amd we will be making a straight rubber version soon for those that prefer it.
Lo-Fi Version | Time is now: 1st May 2024 - 03:50 PM |
