GB from 914Rubber.com A- Arm bushings CLOSING 12/23, $29/59 a set add tools for $30 adtnl. Reg price $48/80 |
Mikey914 |
Nov 30 2017, 11:50 AM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As many of you may be aware there has been a "Cheap" option, that lets say brand "E" has done a video on notating that they are smaller than factory and change the pre-load on the arm.
Brand "U" lets call them has an install video saying that they have recreated the factory part with the same "type and amount of rubber being used" Technically not true because as shown in the video by brand E the durometer is definitely not the same from the deflection noted. With all the BS aside we have made a part like the factory bushing and a special tool to help install these. One of the problems with installation of this part is the end that brand E glosses over. When you get to the part where the tube holds that end from sliding down the shaft you have a "sharp edge" from the metal the rubber can catch on. If it catches you will scar the inside rubber. This will make a second attempt more difficult. We have made the delrin "tools" to allow you to use a 1/2" stainless rod with some nuts and large washers to install. There is a taper to allow the rubber to clear the edge of the A arm without catching it. I had Cary do up one for me and fully document this so that you will have some instruction as how to do this. We are currently compiling and putting this together now. Attached thumbnail(s) |
GregAmy |
Feb 10 2018, 01:30 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Any how-to video/write-up yet? I got motivzated and pulled off a control arm this afternoon (it already has Weltmeister bushings in it) but now I'm holding a beer and starting at it on the bench. I bought the tools with the bushings, do not have a press.
For example, does the bushing go in the holfer first, or on the arm? Do I grease them? If so, both sides? I can go buy some threaded rod - I presume it's avaialble at Lowe's - just pondering life right now. These seem pretty tight; are they going to restrict control movement? Also someone tapped in some zerk fittings. Should I remove those? |
Lo-Fi Version | Time is now: 29th April 2024 - 08:16 AM |
