GB for upper front strut tower rubber bushings, Goes inside 911.341.018.00 $34 a set on GB More later !! |
Mikey914 |
Nov 30 2017, 02:21 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are those pesky rubber bushings that go inside the top of the strut tower mount. Yes you can buy new metal mounts with the new rubber.....at $180 each!
I designed these to allow for install using a press, or with threaded rod, some washers and nuts. Getting the old one out is the hardest part. You can use a sharp knife to cut the upper lip and knock the rubber out the bottom. As the lip is what's holding it in. You can use a press and it will pop out. Install is pretty easy. I designed it to act like a wedge-lock. Align the rubber in the metal part and use a bench vice (or press) to push the two sides together. I used a lower graphite content poly-graphite to allow these to push together under pressure. It creates a wedge lock that will hold the parts in place . You can see that the depth of engagement is correct on the top when the metal tube hits the ends of the bushing. It will be almost fully engaged but will require tightening about 1/8" more down during the install for the strut. I think you will like these, especially for the price! Also good to install while you do the A -arm rubber (IMG:style_emoticons/default/poke.gif) Attached thumbnail(s) |
mb911 |
Nov 30 2017, 03:39 PM
914 Guru Group: Members Posts: 6,822 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
In on these to
7TPorsh |
Nov 30 2017, 04:08 PM
Can these be installed without having to do an alignment?
BeatNavy |
Nov 30 2017, 04:22 PM
Can these be installed without having to do an alignment? Yes, if you are careful. This may help a little: http://www.914world.com/bbs2/index.php?s=&...t&p=2538321 |
yellowporky |
Nov 30 2017, 09:44 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I will take a set too please
djway |
Nov 30 2017, 11:20 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
All in......heck just Main Line me
Mblizzard |
Dec 1 2017, 09:59 AM
Add me! I got to kick this habit but you make good stuff!
toolguy |
Dec 1 2017, 10:06 AM
is a "set" one side or for both right and left struts ???
Mikey914 |
Dec 1 2017, 10:40 AM
Good question,
I typically (95% of the time) refer to a set as a complete car's worth. This is one of those times. I know with my prices I've had people call to ask if it's enough for a car or if they need to order another. (IMG:style_emoticons/default/biggrin.gif) |
Dec 1 2017, 11:09 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
All in......heck just Main Line me Yea, a 914rubber part of the week subscription. Just keep sending parts on auto pay. (IMG:style_emoticons/default/biggrin.gif) |
MikeM |
Dec 1 2017, 11:50 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
I want to order these but don't see them on the website.
Am I missing something? Thanks. |
Mikey914 |
Dec 1 2017, 06:11 PM
On the site now
https://www.shop.914rubber.com/Upper-Front-...m?categoryId=-1 Codes sent to all this far Thanks, Mark |
jim_hoyland |
Dec 1 2017, 08:46 PM
Get that VIN ? Group: Members Posts: 9,271 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How does one know these need to be replaced ?
jim_hoyland |
Dec 1 2017, 08:47 PM
nditiz1 |
Dec 1 2017, 08:54 PM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
restore2seater |
Dec 1 2017, 11:39 PM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
I'm in for a set.
RoadGlue |
Dec 1 2017, 11:44 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
I'm in, thanks!!
914four |
Dec 2 2017, 08:22 AM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
In for a set.
JamesM |
Dec 3 2017, 02:46 AM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
You got me again.
Im in. |
Mikey914 |
Dec 4 2017, 04:42 AM
PMs sent to all this far
Lo-Fi Version | Time is now: 4th May 2024 - 05:23 PM |
