Delete please, Thanks |
jt914 |
Dec 1 2017, 09:02 PM
I love my914 Group: Members Posts: 26 Joined: 20-March 14 From: Pinon Hills, CA Member No.: 17,141 Region Association: Southern California |
Hi guys, I have a lot of 914 parts that need to go. i have all sorts of stuff from all over the cars. If there is anything you need let me know and i'll let you know if i have. prices can't be beat and the more you buy the better the deals. thanks
jason Here is some of it: Front Brake calipers $40 Brake Pistons $5each Brake Hardware $1 and up Master Cylinders $25 Proportioning Valve $25 Hard Brake Lines $5ea Brake Dust Shields$5ea Rear Valance$100 Rear Bumper Core$50 Dog Bones$1ea Fiberglass Rocker panel pair$50 Hella Tail Light Lens pair$100 Hella Side Marker assembly and lens$25ea Tail Light Plastic Nuts$FREE Headlights$10 Headlight Motors$20 Turn Signal Buckets$20 Fuel Injection ECU $50 FI Harnesses$50 1.7 205F Distributors$50 Trigger Points$50 Relay Boards, Covers, Hold-Down Bolts$5-20 Relays $3ea Fuel Pressure Regulators$30 Deceleration Valves$20 Fuel Rails$2ea Voltage Regulators$10ea 1.7 Djet Injection Parts from 1973 Fuel Pressure Sender Connectors and harness parts Coils$10ea 2.0 Manifold$25 Distributor Drive Gears$25 Rear Trunk Lock$25 Rear Trunk Latch and Plunger$25 Inner Door Lock Mechanism $20 Striker Plates$10pr New Front Trunk Weatherstrip Seal $40 Engine Lid Welting Front Targa Latches $25 Window Roller Assembly $25 Front Cowl Seals $5 Dash Skeleton$50 Steering Column$25 Heater Parts Dash Fresh Air Controls$25 Glove Boxes, Doors$10ea Glove box Lock$15 Window Crank Handles$3 Vents$10 Triangle side window glass$10 Rear window$25 Coat Hooks$10 Front Trunk Release Handle and Lock$15 Pedal Clusters$50 Pedal Cluster Parts Pedal Boards$10 1.7 shortblock has not been split open w crank, cam, rods$200 Cranks 1.7 $50 Connecting Rods 1.7 $50set Rocker Arm Assembly 2.0 $100 Oil Coolers$10 Pushrods and Tubes$2 1.7 Heat Exchangers blasted and painted$100 1.7 Heads $100 2.0 Head 75-76 needs repair $40 Valve Covers and Bales $30 Driver seat$60 Seat Tracks$25ea Center pad and plastic tray $15 Fuel Combo Gauge Silver Dot$30 Gauge Bezels Metal $20 or Plastic$10 914 A-arms$80 Front Struts and Spindles$50 . And so I don't break any more rules, I wish to be paid in cash. Or paypal if parts need shipped. plus actual shipping and packaging if needed. |
Kurbis |
Dec 15 2017, 12:57 PM
Newbie Group: Members Posts: 5 Joined: 6-October 17 From: Pittsfield NH Member No.: 21,490 Region Association: North East States |
If the brake dust shields are from early model and they are rears and if you have two I'll take 'em.
Lo-Fi Version | Time is now: 7th May 2024 - 07:55 PM |
