Who has mounted Mikey’s Fender Liners?, 914 Rubber Issue |
RickS |
Dec 2 2017, 10:28 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Just received the box with the liners. Instead of the stated “clips” for mounting they came with rivets. Clips suggest clipping the liners to the fenders or other attachment points rivets on the other hand... Am a bit hesitant to start drilling holes in my original sheet metal. No instructions were provided either.
Any one done this or have suggestions of the least invasive way they mounted these not using “clips”? |
RickS |
Dec 9 2017, 09:20 PM
Here is the clearance issue with mounting the rear There just doesn’t seem to be room to fit the liner with the bracket since it hits the suspension. Also how do you get to the zirk with the liner in place?
if the solution is to mount the L bracket on the inside, how do you access the bolt to remove the rocker without drilling out the rivers? I am repainting the rockers and was going to put them on last. |
Lo-Fi Version | Time is now: 8th May 2024 - 02:38 PM |
