73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
R Dub |
Jun 11 2019, 12:17 PM
Got the motor back from McMark a couple weeks ago. This weekend I got around to putting it all together and getting it in the car. Was able to get it started and ran for a bit. Then out of no where it died and couldn't get it to restart.
First thought I had/do have a fuel pump problem. The fuel pump sometimes wouldn't prime but when you wiggle the relay it does. I will buy a new relay in hopes of fixing this but jumped the pump just to get the motor running again. However it wouldn't fire. Upon inspection one carb is not squirting fuel and not sure why, while the other works. I suspect a stuck needle and seat (IMG:style_emoticons/default/confused24.gif) I'll take the carb off the car and tear into to to see if I can see one. Really kinda bummed cause I thought I would be driving it again this weekend. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:30 AM |
