73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
R Dub |
Jun 19 2018, 12:43 PM
Haven't posted in a while cause I haven't touched the car up until yesterday when I drove it for the first time ever which was AWESOME (IMG:style_emoticons/default/smilie_pokal.gif)
Finally got some time so my dad and I got to work on the car. First started out by fixing the one rim that had a slow leak on it. Had to have a shop dismount the tire then take it apart, clean it up and re-silicone it then have it remounted. Then had to put the carbs back together and put back on the car. Wasn't thrilled with the company I sent them to as they did not do what they said, it took double the amount of time, charged me ~$200 more than quoted and he sent them back in pieces instead of together. Went to start it only to find out the fuel pump died so had to go buy a new one and spend some time at the hardware store to get the new one plumb like the old one to use the same mounting points, hoses, etc. Once we got all of that figured out, the fuel pump wouldn't turn on with the key for some reason. Will have to look into that more as we are getting 12V to the positive wire and it is grounded. We used a jump box to bypass it and it works so I drove it around the block a couple of times. It was an truly awesome feeling. Still got a while to go until it is "done" but it's almost road worthy again! |
rjames |
Jun 19 2018, 05:03 PM
I'm made of metal Group: Members Posts: 3,922 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Haven't posted in a while cause I haven't touched the car up until yesterday when I drove it for the first time ever which was AWESOME (IMG:style_emoticons/default/smilie_pokal.gif) Finally got some time so my dad and I got to work on the car. First started out by fixing the one rim that had a slow leak on it. Had to have a shop dismount the tire then take it apart, clean it up and re-silicone it then have it remounted. Then had to put the carbs back together and put back on the car. Wasn't thrilled with the company I sent them to as they did not do what they said, it took double the amount of time, charged me ~$200 more than quoted and he sent them back in pieces instead of together. Went to start it only to find out the fuel pump died so had to go buy a new one and spend some time at the hardware store to get the new one plumb like the old one to use the same mounting points, hoses, etc. Once we got all of that figured out, the fuel pump wouldn't turn on with the key for some reason. Will have to look into that more as we are getting 12V to the positive wire and it is grounded. We used a jump box to bypass it and it works so I drove it around the block a couple of times. It was an truly awesome feeling. Still got a while to go until it is "done" but it's almost road worthy again! Fuel pump- check the relay on the relay board in the engine compartment. All the relays are the same so you can swap the existing ones around to find a good one (assuming there's a good one to be found). |
Lo-Fi Version | Time is now: 4th May 2024 - 12:17 AM |
