73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
R Dub |
Nov 11 2018, 07:35 PM
Got the fuel pump figured out but found out that oil was leaking out of the push rod tubes and 3 of 4 cylinders had low compression. One was as low as 60 psi. So we pulled the engine out and pulled the heads and cylinders off. Found a few issues. First is a couple of the push rods are bent and the second issue is the cylinders have some scoring on them which we believe to be from rust as the car sat for 20 years. Now a few questions (and sorry for being a total nub):
1) Where can I find new push rods. I've searched Google and all I can find is new push rod tubes, which I'll get as well, but not push rods. 2) Anything I can do to a 2.0L to gain some performance? I'm looking for more bolt on stuff, not looking to machine the block or heads or anything like that. I've read something about a 2056? Is this just bolting on bigger cylinders and pistons while leaving the crank, rods and head all stock? 3) I'm going to replace the alternator belt and some grommets while it's out. Anything else I should replace while the engine is out? |
Lo-Fi Version | Time is now: 4th May 2024 - 10:01 AM |
