73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
bbrock |
Jan 12 2019, 11:10 PM
There are several threads on the swivel foot adjusters. I think this one should answer most of your questions: except the last one: http://www.914world.com/bbs2/index.php?sho...327102&st=0
R Dub |
Jan 13 2019, 04:24 PM
There are several threads on the swivel foot adjusters. I think this one should answer most of your questions: except the last one: http://www.914world.com/bbs2/index.php?sho...327102&st=0 Thanks so much for the reply. This does help, not sure why I couldn't find this in my initial search. It does look like you need to cut the rockers down in order to accept the 911 adjusters. To be honest I don't really like this idea. Also right now I Plan on going with the stock valves, not SS and if this car see 2000 miles a year I would be surprised. Based on what I've read, the stock 10MM adjusters should do the job just fine for my application so I will most likely go that route. |
Lo-Fi Version | Time is now: 4th May 2024 - 03:51 AM |
