73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
R Dub |
Jan 27 2019, 03:36 PM
Just ordered about $630 worth of seals from 914rubber. Hopefully the car will be all sealed now.
Got to look at the heads just a bit yesterday. Found out the adjuster screw on the rocker is 8MM and not the stock 10MM. Not really sure why though. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1548624974.1.jpg) Also not sure if this is a issue or not. Really hoping not cause buying new heads was not in the budget. I'm going to contact a local shop tomorrow to see if they can inspect and rebuild if possible. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1548624974.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1548624975.3.jpg) |
Lo-Fi Version | Time is now: 4th May 2024 - 10:12 AM |
