73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
R Dub |
Mar 5 2019, 02:23 PM
Quick update:
The heads are with Adrian at Headflow masters. He called saying they are repairable and will do a complete valve job including new stainless valves, springs, guides and seats. He said the SI valves he uses will work well with the stock adjuster screws. He suggested going with bigger valves, 44x38, since the car is running carbs so that will be getting done as well. Just ordered 96mm Keith Black piston and cylinders from FAT Performance along with a new 86 grind cam, solid lifters and a new cam gear from Web Cam. Will be ordering the rest of the stuff such as bearings, gaskets, seals, clutch, push rods, etc very soon. Hope to have all the parts arrive within a couple of weeks so I can start to rebuild. I did pick up the Tom Wilson rebuild book so hopefully it goes fairly smooth. I'll post pics of the new parts and progress as soon as I get them. |
Lo-Fi Version | Time is now: 4th May 2024 - 08:29 AM |
