73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
R Dub |
Jun 15 2019, 08:53 PM
Update. Put the new relay in and fuel pump seemed to work great. Hopefully that fixed that issue.
Took the carb off and found out that the roll pin came out of the cam and was not lifting the lifter. Therefore as a result it was not squirting fuel. Put a new roll pin in there and it fixed that issue. Then got the car running and pretty well. Adjusted the timing and everything seemed to be running good but then.... Went to turn the car around on the lift so the back was facing the garage door so we could run the car for a while to dial in the carbs. While driving up, the external oil cooler drain bolt hit the lift and cracked the housing and oil started to leak everywhere. Honestly my grandpa had all of the external oil cooler lines run pretty poorly so I will now have to redo all of them. Below is a pic. Now I Need Help! 1) I need to know where does the oil temp sender wire plugs into under the battery? I looked everywhere and couldn't find it. The wiring is not stock so I'm sure that doesn't help 2) At idle the volts is just under 12 and then when you hit the brakes or turn signal it drops to under 10. Is this normal? If not, what should it be and how do I tell if the alternator is bad or something else? If something else, where to start? (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ibb.co-21387-1560653615.1.jpg) |
Lo-Fi Version | Time is now: 4th May 2024 - 05:50 AM |
