73 914 2.0 Rebuild |
R Dub |
Dec 3 2017, 02:34 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
timothy_nd28 |
Dec 30 2019, 01:00 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Yes, the old light bulbs are not used anymore when you do my LED conversion. Each gauge has its own LED strip, and a connector at the rear of the gauge. A small wiring harness connects each gauge together, which leads back to a hidden controller. I did a few write ups for people that want to do this themselves.
I've been out of the game for a few years, and wow how these RGB LED's have changed! In addition to that, this forum has also changed. I received a PM from a member, and it had a embedded picture! When did that happen? lol Trying to keep up with these new style LED's, I'm experimenting with RGB+CCT LED's on another members car. This new LED has the original RGB function, but with two extra white LED's. Consequently going from 4 wire to 6 wire LEDs, which changes my setup quite a bit. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:10 AM |
